Results 1 to 6 of 6
Thread: Newbie help!
    Xtreme Cruncher
    Dec 2008
    Texas
    Newbie help!
    So, been a long time since I said I would join, but I could never get it to work on Vista (now I have win 7)
    Got it up an running (I think). Are there any settings I should change to maximize points?
    Any other tips?
    Thanks guys!
    24 hour prime stable? Please, I'm 24/7/365 WCG stable!
    So you can do Furmark, Can you Grid???
    Jan 2009
    Chandler, Arizona
    I'm not an expert but I've been told running multiple virtual machines, each running DIMES is a fast way to gain points. I just have it installed as a service on each of the machines in my house, its working even thought I don't realize it.
    -trekie86
    Antec 900 Black
    Rosewill 600W RP600V2-S-SL
    Gigabyte EP45-UD3P Rev 1.0
    Intel E8500 @ 3.8 GHz
    2 x 2 GB GSkill PC6400
    EVGA Geforce GTX 260 Core 216 SSC 55nm
    EVGA 8800GTS PhysX
    640 GB WD HDD 7200 RPM
    Quote Originally Posted by dengyong View Post
    Started life as a FTW and ended up as a WTF.
    Xtreme DČOL Watch Dog
    Feb 2005
    Canada
    Get TinyXP and you can run it in a VM with only 48MB of RAM so you can run 24 VMs on one machine.
    Xtreme Cruncher
    Jun 2005
    Northern VA
    also, you need to look at some of the older posts of for the last year, there is a bunch of tips and tricks to get the most out of dimes.
    one of the best ones is VMWorkstation, its free for 60 days, set up your vms, put a master one on a thumb drive, and youll be able to look at the vms after the 60 days. before the 60 is up get vmplayer, to keep all the vms going and your golden for as many vms as you can put on each rig, as long as you have the memory for it....
    Its not overkill if it works.
    Xtreme Cruncher
    Dec 2008
    Texas
    So apparently this doesn't like to be on wifi... 3 days and nothing. I plug it in and suddenly it's making a map...
    Moderator
    Mar 2006
    Quote Originally Posted by Otis11 View Post
    Ah. Must be some settings in teh config page that got mixed up. It should work on any connection.
