+ Reply to Thread
Results 1 to 7 of 7
Thread: 5xxx series and PCMARK05
    Jun 2009
    0
    Hi guys
    I recently got 5770 CF and when I ran PCMARK05 I got a terrible score compared to with my old 9600 GT. I think it has something to do with the bad 2d clocks on the 5xxx series. I saw AndreYang got nice results in the GPU tests in PCmark05 with a 5870 but I don't know how to get my cards to perform properly for the benchmark.
    Thanks.
    One-Eyed Killing Machine BenchZowner's Avatar
    Sep 2006
    Inside a pot
    49
    You need to raise the 2D clocks.
    Make sure you run it on Windows Vista with the Aero theme enabled.
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
    Jun 2009
    0
    Yeah but how do I raise the 2d clocks then? I'm using MSI afterburner.
    Also why Vista? 7 is working fine?
    Sep 2006
    Inside a pot
    49
    I don't remember if there's a tool to raise the 2D clocks of the HD5xxx series in realtime, but I do know for sure that you can do it with a BIOS edit with RBE ( Radeon BIOS Editor )
    Xtreme Cruncher Musho's Avatar
    Dec 2008
    The Netherlands
    11
    Make sure you up the 2d voltages as well then. Running 3d clocks at 2d voltage will instantly crash your card :p
    Jun 2009
    0
    editing bios is too much work for me :p
    Slayer X mike's Avatar
    Apr 2005
    Las Vegas
    2
    don't run CF
+ Reply to Thread
