Results 1 to 3 of 3
Thread: Will I have enough flow?
    Aug 2009
    Louisville, KY
    Quick question for the pros from a newb ..
    Single Loop consisting of...
    GTX 480 Rad
    EK Multi 150 Res
    EK P6T Block / Mos 1 / Mos 2
    EK Supreme HF
    EK 5870
    Pump is MCP355 with a XSPC 3.0 Top.
    Will I have enough flow with this loop or will there be too much restriction?
    May 2008
    Durham-UK
    you will be fine with that setup the 355 is more than enough
    The Blood Of 1000 Angels: AMD Phenom II X3 720 @ 3.8GHz with 4th Core Unlocked| DFI DK 790GX-M2RS|2X2GB G.Skill DDR2-1066 PK (F2-8500CL5D-4GBPK)| 2x Seagate 320GB 7200.12 In RAID-0| XFX 5850 XXX@ 1000/1200| CM Cosmos 1000| Samsung T240 1920x1200 CPU Cooling:IandH Stealthres 175| Swiftech 355 w/ XSPC Top| XSPC RS240|EK 5850 Copper and Acetal|XSPC RS360|Swiftech GTZ
