gtx285 clocks
just curious what yall are running your gtx 285's at. I just bought a used one and stock is
Here is my GTX-285 on GPUGrid ...
http://www.gpugrid.net/show_host_det...p?hostid=56900
Shaders @1584 cranks out a GIANNI_BIND in 6 hours.
Fan didn't go much over minimum and stayed very cool.
those clocks look very similar to the GTX 275 superclock speeds, just a little higher on the memory clock. I would say that you should possibly be able to get to 1620 on the shaders as the 275's, but may be pushing it a little. I will have to agree with Snow on this one, but I do not own one either.
this seems to be fine. small oc..
I usually set my fan @ 60
- You may not post replies
- You may not edit your posts
Forum Rules
