+ Reply to Thread
Results 1 to 10 of 10
Thread: NVIDIA Ion 2 platform built on GeForce G310
    I am Xtreme zalbard's Avatar
    Dec 2008
    Germany
    33
    Talking NVIDIA Ion 2 platform built on GeForce G310
    Source: http://www.nordichardware.com/
    NVIDIA is about to launch the second generation Ion platform. From being a chipset with an integrated GPU it had to rethink when developing Ion 2. Intel has moved the northbridge and a GPU inside the new mobile processors. Since most of the chipset features are now already available inside the new Pineview Atom and Arrandale processors, the Ion 2 platform doesn't need to be a chipset but more or less just a graphics circuit.
    The specifications from a new all-in-one PC from ASUS has listed NVIDIA's GeForce G310 GPU as "ION2 Graphics".
    ASUS Eee PC ET2010PNT is a 20" all-in-one PC based on the Intel's Atom D510 CPU with dual cores and integrated graphics circuit for a really energy efficient system. Connected to a GeForce G310 GPU there is additional power to fetch when needed. This looks to become NVIDIA's banner for the Ion 2 platform.
    As suspected NVIDIA's Ion 2 platform will be more like an discrete GPU than anything else now that Intel has revised its mobile processor design. GeForce G310 is more or less a renamed GeForce G210 GPU, but that will still be enough to trump the performance of the first generation Ion (GeForce 9400M).
    Wow, haha, looks like I was a bit overly optimistic about Ion 2 specs!
    Donate to XS forums
    Xtreme Member NickF's Avatar
    Jul 2006
    1
    The GeForce G210 has 16 processor cores and a 589MHz CPU clock speed; that’s paired with 512MB of DDR2 memory with a 64-bit interface and 500MHz clock speed. Its shader runs at 1,402MHz.
    The GeForce 9400 GT has 16 Stream Processors. 550 MHz core, with a 1350 MHz unified shader clock.
    Desktop variants don't sound too different on paper. Would have been nice to pull a 32-stream processor variant to replace the ION, but it looks like they focused entirely on cutting back die area and power consumption.
    eXt 4
    Intel Core i5 2500k @ 5GHz | Asus Maximus GENE-Z | Corsair Vengence 16GB DDR3-1600 9-9-9-24 | eVga GTX 580 SC 1000/2300 | SeaSonic Platinum Platinum-860 | Corsir Force GT 60GB/WD Green 1.5TB
    XSPC dual bay res w/ Laing D5/ XSPC Raystorm CPU Block / EK-FC580 GTX+ GPU block / XSPC RX240 / XSPC RX360 / All Yate D12Sm-12 Fans / NZXT case
    St0rage
    AMD Phenom II 965 @ 3.6GHz | Gigabyte MA785G-UD3H | Corsair XMS 8GB DDR2-1066 | 785G integrated | Corsiar TX 750 | WD Green 2.0TB
    Thermalright VenomousX, ALL Yate D12SL-12 FANS
    Xtreme Member Spectrobozo's Avatar
    Jan 2004
    3
    I think the desktop version of the 9400m GT (with dual channel memory) is faster than the g210!?
    Xtreme Addict Monkeywoman's Avatar
    Jun 2007
    above USA...below USSR
    1
    i had hopes for Ion 2 when i heard it was getting 32 cores (http://www.slashgear.com/nvidia-ion-...9400m-0148419/ ) but now seeing big green wants to milk the market by over clocking the chip and throwing "2" on it....not impressed
    Id like to see some competition other then that broadcom hd chip.
    i think having intel say, "ion is overkill" for netbooks has something to do with it.
    Case-Coolermaster Cosmos S
    MoBo- ASUS Crosshair IV
    Graphics Card-ASUS MATRIX 5870 2gig
    Hard Drive-Kingston 128Gb SSD v2 master Seagate 160Gb slave Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
    CPU-AMD X6 1090T 4300 MHz 24/7
    RAM 8Gig Corshair c8
    Logitech 5.1 Z5500 BOOST22
    120Gb of MUSICA!!
    SonyPlaystation 3 SECHE01 320gig Western Digital Scorpio
    Steam ID: alphamonkeywoman
    http://www.techpowerup.com/gpuz/933ab/
    Xtreme Addict RejZoR's Avatar
    May 2007
    Europe/Slovenia/Ljubljana
    0
    How can it be an overkill if it still struggles with certain stuff. Lots of games can be played on netbook but some still run like crap.
    So 32 vs 16 cores might not be much but it might reflect in games. I'd love to have ION based netbook but they were not aavailable when i was buying netbook and when they arrived, they were a bit too expensive.
    Intel Core i7 920 3.8GHz | 6GB Corsair Dominator | ASUS Rampage II Gene | GIGABYTE HD7950 3GB WindForce 3X | WD Caviar Black 2TB | Auzentech X-Fi Forte | Altec Lansing MX5021 | Corsair HX750 | Lian Li PC-V354
    Super silent cooling powered by (((Noiseblocker)))
    Jul 2006
    1
    Hmmm Seems like it won't be such fail afterall:
    http://www.fudzilla.com/content/view/17349/1/
    In addition to the announced Pinetrail/Geforce 210 motherboard, Point of View is working on other motherboards that will pack some serious graphics power. The new ones should be similar to the previously announced Pinetrail/G210 based motherboard but will feature GT 220 and GT 240 graphics cards hooked up to the PCI-Express x1 slot.
    eXt 4
    St0rage
    Aug 2006
    3
    According to 3dmark from the 210m it will be twice as powerful as the 9400m/ION 1st gen. Which is a good improvement.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    Quote Originally Posted by tdream View Post
    who benched it?
    the only score i saw was from nvidia... so... forget about that! :P
    Aug 2006
    3
    Quote Originally Posted by saaya View Post
    who benched it?
    Nobody yet.
    I'm estimating from these charts
    http://www.notebookcheck.net/NVIDIA-...M.17638.0.html
    http://www.notebookcheck.net/NVIDIA-...G.11949.0.html
    Dec 2008
    Germany
    33
    ION 2 bench delivers disappointing results
    Source: http://www.fudzilla.com/content/view/17790/1/
    15 percent slower than the original ION
    As if Nvidia was not in enough trouble as it is, it turns out that the new ION 2 might not be brightest GPU in the bunch.
    According to a review on netbooknews.de, ION 2 fails to outperform the original ION. The reviewers pitted the Samsung N510 with ION graphics against the ION2 packing Acer Aspire one 532G. The ION-based Samsung scored 3513 in 3D Mark003, while the Acer managed just 3049.
    This is a 15 percent difference, only in the wrong direction. However, it's worth noting Nvidia will probably launch new drivers to improve performance, as the results simply seem illogical. Whether or not the ION 2 will indeed end up faster than its predecessor remains to be seen.
    More here.
    Good improvement, innit?!
    Donate to XS forums
+ Reply to Thread
Tags for this Thread
