+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: Gigabyte and ACC issues
    Jul 2007
    0
    anyone here have issues applying ACC on their gigabyte board with Phenom II x4's? I can't make it into windows regardless if I've adjusted them or not with ACC enabled.
    25 to life - Eminem chew*'s Avatar
    Jan 2005
    Hell on Earth
    0
    Problem is according to AMD phenom II was not / is not designed to work with ACC and I quote there is no benefit to running ACC on phenom II......
    Of course we do know it unlocks chips but it obviously does diff things to the chips now that it was not doing to phenom I. Other than for unlocking chips they probably should have done away with it altogether on ddr III boards due to the fact PH I is not supported..........My guess is ACC function is not even part of the spec for AM3.
    heatware chew*
    For every beginning there must be an end
    Will be around to help with AMD specific hardware till shortly after BD launches, after that I'm Ghost
    Jul 2007
    0
    I've actually had good results from enabling it on other boards. Most recently the MSI GD-70.
    Jan 2005
    Hell on Earth
    0
    Quote Originally Posted by NCspecV81 View Post
    Regardless it's unsupported and not part of "spec" however i have seen it help in rare cases on mobo's that tend to have a fair amount of droop......Ive said this before but if it does help than chances are your missing something in your manual tuning that ACC is "fixing"
    I've played with a few times in all types of conditions, its actually given me worse results with chips that are natively 4 core by model designation, if i had to guess i used at least 15 various boards testing it.
    I think if anything it has a placebo effect on users. People are so convinced it actually does something that they truly think it helps when in actuallity it's doing nothing.
    heatware chew*
    I am Xtreme BeepBeep2's Avatar
    Jan 2009
    Ohio
    361
    Quote Originally Posted by chew* View Post
    In a guide from AMD for "tweaking" Phenom II's said that you can use ACC to tweak weak cores to up total clock frequency. I need to look it up again...
    Jan 2005
    Hell on Earth
    0
    Quote Originally Posted by BeepBeep2 View Post
    That was it's purpose in PH I when ocing the chips at all was a strain.
    heatware chew*
    Jan 2009
    Ohio
    361
    No there was a guide made after macci, sampsa, and SF3D gathered at the XS Las Vegas event and it was an AMD .pdf but it's nowhere to be found on their site. I was reading it just a few days ago and should have bookmarked it. I know it showed that you can use ACC "to reach higher frequencies on the weaker cores of your Phenom II processor"
    Jan 2003
    Sweden
    0
    +1 i have seen that to... but i have not any luck with it...maybe on some boards it works well.
    Jan 2009
    Ohio
    361
    Here is is:
    Completely inaccessible from a search engine...I looked for it about 6 times then gave up. It was in my history from Thursday on my netbook.
    http://game.amd.com/us-en/content/pd...ning_Guide.pdf
    In case of the AMD Phenom II CPU, the “Advanced Clock Calibration” (ACC) feature can be used to
    improve the tuning margin of specific CPU cores. Typically the CPU core that has the lowest tuning
    margin by default is the likely candidate to see benefit from ACC-feature.
    ACC can be enabled thru the AMD OverDrive™ utility or from the BIOS menu. Select the “Per Core”
    option and set the value of ACC to “+2%” for the CPU Core that has the least amount of headroom. Set
    the rest of the CPU cores to “0%” (default value).
    Note that the system needs to be restarted before the new settings will be applied. Restarting the
    system is required each time the value(s) of ACC are adjusted.
    Jan 2009
    Ohio
    361
    Adding to the OP, I'm running the board in my sig right now with ACC on, Per Core: Core 0 +2, Core 1 0%, Core 2 +2, Core 3 +2.
    Booted into windows fine, Phenom II 965 BE C3.
    EDIT:
    I'd also like to know why my idle temps at 4016 Mhz 1.50v are 33c now, 6c lower than the 39-41c from before. I'm more than slightly confused.
    Xtreme Addict crazydiamond's Avatar
    Jan 2008
    milwaukee
    11
    i know a few other guys around here also said their phenom II oc's benefited from tuning ACC
    LEO!!!!
    amd phenom II x6 1100T | gigabyte 990fxa-ud3 . .
    2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd
    sapphire ati 5850 | x-fi xtrememusic. . .
    samsung f4 2tb | samsung dvdrw . .
    corsair tx850w | windows 7 64-bit.
    ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . .
    lycosa-g9-z2300 | 26" 1920x1200 lcd .
    Feb 2009
    0
    re
    This is absolutely GOLD!
    Don't have time to read it now, but I will!
    That thing is a Noob question shield!
    Mavhenz --> happy!
    Jan 2009
    Ohio
    361
    forget it, ACC normal mode doesnt even set...it reverts to "disabled"
    hybrid I lose core temps and it has no effect...just for core unlocking.
    Jul 2007
    0
    yeah I can't get ACC to work at all. I'm bummed.
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    210
    lol, with ACC u got better temps?!
    AMD FX-8350@5 GHz 1.52V + H100 Corsair, Crosshair V Formula-Z, 2x 4GB GSKill TridentX 2400 MHz+ 10-12-12-25, EAH HD6870 DirectCU, Corsair TX850W
    CPUs:next 2x AMD FX-8350, AMD FX-8320, AMD FX-6300, AMD FX-4300, AMD FX-8150, AMD X2 555 BE, AMD x4 965 BE C2 and C3, AMD X4 970 BE, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD X6 1100T BE, AMD FX 8120 95W, AMD FX 8120 125W, next AMD FX-8150, AMD A10-6800K, 2x AMD A10-5800, AMD A10-5600K, AMD A8-3850, AMD A8-3870K, 2x AMD A64 3000+, AMD 64+ X2 4600+ EE, Intel i7-980X, Intel i7-2600K, 2x Intel i7-3770K, Intel i7-3930KAMD Cinebench R10 challenge
    Jul 2007
    0
    put the 955 on my gigabyte...now lets try this!
    Jan 2009
    Ohio
    361
    ACC doesn't even turn on...*frets*
    Hybrid does nothing but turn my temp sensor off...normal...does nothing and wont turn on.
  18. #18
    Jan 2009
    Ohio
    361
    Flashed F8 on my board and I'm experimenting...first I saw hope...no more BSOD's and individual cores failing in OCCT...
    Now, after messing with "Per Core" values I'm getting random IRQL_NOT_LESS_OR_EQUAL BSOD's and DRIVER_IRQL_NOT_LES....with an occasional "An attempt to execute non-executable memory blah blah"
    My theory is that "set in stone" optomized values are set for each core as they leave the factory however sometimes they can be a smidge off. Setting +2 on my first and last of the four cores definately helped stability. +4 just tanked into the ground...core one took it but setting +4 on core four ended in me not being able to boot windows.
  19. #19
    Jul 2009
    Cape May
    0
    .i think if anything it has a placebo effect on users.
    qft
    Imo, same thing with 955 C3 compared to 965 C3(which binned higher by manucftr).
  20. #20
    Jan 2009
    Ohio
    361
    Well, Macci is the one that stated a positive ACC value can push more Mhz out of weak cores on a Phenom II CPU...;-)
  21. #21
    Jul 2009
    Cape May
    0
    Same settings with ACC disabled
  22. #22
    Jul 2007
    0
    which gigabyte board is that with acc enabled? I still can't get it to work.
  23. #23
    Jan 2009
    Ohio
    361
    Gigabyte GA-MA790X-UD4P with F8 bios for me...
  24. #24
    Jan 2009
    0
    I was in the same thought as you are Chew regarding ACC and PII's though I'd heard mumblings on the net that some people had found a little help from it. I decided to try it out myself after I also came across that guide specifically mentioning Phenom II and ACC. The guide states that you are supposed to use the 'Per Core' option not auto or anything else even given an mention.
    I finally decided to try it out myself on a core by core basis. I loaded up the system with stock 1.35v (PII 955), and clocked each core independantly using K10stat. For stressing I decided to use LinX with a quick 5 minute run to start out. I settled on 3.8Ghz for the core speed that I was testing which was no problems for Cores 0 & 1. Core 3 made it to 3.7Ghz and a few seconds on 3.8, Core 2 didn't make it at all at 3.8Ghz so I started there. I ran the test a few times and never made it anywhere (as in less than 5 seconds).
    I went into the bios and left everything the same, but enabled ACC Per Core with a +2 on Core 2 only. I went in and ran the test again and actually made it somewhere which was surprising, but still failed in 30 seconds. Ran the test again with +4, and made it about 1 minute or more. Went the other way with ACC (like I was used to wiht Phenom I) and tried out -2%......ran for the full 5 minutes without a problem. I ran it again without the ACC and it failed just as fast as normal, added the ACC -2% and it ran just fine.
    I did the samething for Core 3 and ran the test for 5 minutes, no problems at all. I tried to run it for 10 minutes on Core 2 but it failed at 7 minutes so I bumped the volts 1 click and it passed everything I threw at it after that regardless the length of time.
    Without using ACC on those specific cores (after finding out exactly what the core needed individually) I wasn't able to run at those speeds on the stock voltage at all. It seems to me that somehow it does indeed help in that situation. Of course everyone will not have the same results nor the same % needed, some may not get any help at all.
    It was interesting though to see that it actually did help even on a Phenom II.
    Kei
    Board for test wasx ASUS M4A78T-E with Phenom II 955 processor (haven't tried it much on my Gigabyte MA770T-UD3P yet except the -2% on Core 2 when running early tests which still helped)
    Phenom II X4 955 running 3.2Ghz @ 1.168v| Gigabyte MA770T (temp board)| ATi 5770|G.Skill 4Gb 1866Mhz cas8 1T Ripjaws| Cooler Master 650W| 160& 250Gb HDD's non raid config| CD/DVD Burner| HD DVD Drive| Blu-ray DVD Drive| Cooler Master V8 stock fan on lowest setting (lapped)
  25. #25
    Jan 2009
    Ohio
    361
    Quote Originally Posted by Kei View Post
    Kei
    I'm getting the same type of results here...auto does complete squat, but if I set per core I gain some headroom. Even my best core seems to prefer -2%...I've got core 0 @ +2, core 1 @ -2, and cores 2/3 @ 0%.
    I've gotten two cores tweaked, and now I'm moving on to the other two...it's time consuming but in the end it's worth the extra 50-75 to 100 Mhz
+ Reply to Thread
