Results 1 to 25 of 25
Thread: The motion of the ocean; small reciprocating
    -150c Club Member
    May 2005
    Northeast, USA
    It's a 1/5hp little unit, r404a compressor, copeland.
    Chilly1 blue with 100cfm 110vac fan.
    20" Flex line, Chilly1 evaporator, unmodified.
    250W @ -26.5C
    200W @ -30.5C
    150W @ -35.4C
    At 250W, 240psi high side, 30psi low.
    The charge is primarily R402a.
    Captube is .031" capillary tube, probably around 6ft right now.
    Custom accumulator and SLHX.
    Small format, and pictures of the base coming up later, nice steel framework with some paint. Size fits for drop into a V2000 if my measures are correct.
    Compressors a bit warm at 33C, but overall not even that bad. Still producing very little noise, quieter then a NF9FX on r134a The noise is all in that fan, but it's needed for the moment with this kind of condenser.
    Hope you enjoy.
    If you have a cooling question or concern feel free to contact me.
    Admin
    Mar 2003
    North Texas
    Very impressive Adam
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    -150c Club Member
    May 2005
    Northeast, USA
    Just trying to show that compressor size is not the problem anyone should be thinking.
    You don't need to go big at all.
    Xtreme Mentor
    Feb 2007
    Victoria, British Colombia
    its a cute little guy and looks to perform the part. nice unit
    Administrator
    Nov 2007
    Stockton, CA
    what is the actual size of the full unit ?
    Nice job NOL
    -150c Club Member
    May 2005
    Northeast, USA
    18 by 8 by about 8 tall.
    The unit fits within those specs easily.
    Administrator
    Nov 2007
    Stockton, CA
    That will fit in the bottom of a modded TJ07
    Xtreme Mentor
    Aug 2006
    Atlanta
    Hmmm r402a?
    Never empower an idiot with a response....
    http://en.wikipedia.org/wiki/Troll_%28Internet%29
    Seller/Buyer Reputation:
    Heatware: http://www.heatware.com/eval.php?id=50905
    Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
    Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
    iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
    -150c Club Member
    May 2005
    Northeast, USA
    Yep R402a.
    Nov 2004
    Small and very efficient. Definitely my favorite combination. It is interesting seeing your pressure readings as I've just got done logging mine over the past few hours with HP80. You cool with applying this build here to 1hp+ and .036? :P lol
    Banned
    Nov 2009
    Nice Adam, i like it
    Mar 2008
    Minnesota
    If you make any more smaller units like this...PM me
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Dec 2008
    Sycamore ILLINOIS
    now that would beat the crap out of my current plans for my v2000 just about perfectly. (just noticed after writing this you say it would fit in a v2000, want me to test fit it ) For a 24/7 system it would be lovely, assuming your board has overheating shutdown in the case something goes out. And 250w that's nice, what kinda peak startup wattage does it draw, around 450w?
    Last edited by lesstutrey; 01-20-2010 at 01:04 AM. Reason: i never get it right the first time
    Jan 2007
    Detroit, MI
    Nice Adam. I like this. Not too sure on the wattage output on the processors these days. What would 250w be equivalent too on a recent chip?
    My Custom Pressure/Temperature Charts for Various Refrigerants
    QX6700 @ 3900 | EVGA 680i |2 GB Corsair 8500 Dominator | 7800 GT SLi | Silverstone 1KW | Seagate 7200.9 Barracuda RAID 0 + Hitachi Deskstar 2TB RAID 0 | SS Phase w/ Cryostar Evap | MIPS Full Motherboard cooling
    My Fake Quad Core is better than your real Quad Core! **cough**Barcelona**cough**
    Lian Li Cube Case with Phase and Water DONE!!
    Xtreme Mentor
    Aug 2006
    Atlanta
    Quote Originally Posted by TopherTony View Post
    Honestly its hard to say but most folks seem to think an i7 loaded with 8 cores is hitting 300 watts.
    -100c Club
    Jun 2005
    Slovenia, Europe
    Not trying to be an a$$hole, but R402a is worldwide forbidden in new cooling equipment as of Jan 1st 2010, the same goes for R-22a. I think R-507 would be a good drop-in replacement. Maybe a degree or two warmer evaporator but also few Psi lower discharge.
    Xtreme Mentor
    Aug 2006
    Atlanta
    Quote Originally Posted by tiborrr View Post
    Seriously I wasnt aware of that r402a was illegal...
    They still sell it: http://www.r22.org/prod_list.php?sci=16
    But maybe its just for maintenance of existing systems.
  18. #18
    May 2009
    Upstate, SC
    im pretty sure the refrigerant police are going to be checking everyones home built phase change units...
    SYSTEM
    i5-3750K @ 4.6ghz - ASRock Z77 Extreme4 - 16GB Samsung DDR3 - Sapphire R7 370 Nitro 4GB
    Water Cooling
    EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
  19. #19
    Feb 2006
    Potosi, Missouri
    The EPA published the rule on 12/15/2009 banning the sale or distribution of new systems using HCFC-22, HCFC-142b, or blends containing one or both of these substances effective after 01/01/2010.
  20. #20
    -150c Club Member
    May 2005
    Northeast, USA
    Yep; but that doesn't really bother me. I'm out of r402a and technically she was charged Dec 30th so woopie
    Time to start working with my new tank of refrigerant
  21. #21
    Nov 2005
    Louisville, Kentucky
    Manufacturers cant make New equipment With R22 R402 But it will still be available for service work for a while. Or at least here in the USA
  22. #22
    Champion
    Jan 2004
    Athens , Hellas
    Excuse me for this question .
    Checking a pt chart of r402a , the temperatures dont match.
    http://www.refrigerants.com/pics/ptchart.pdf
    30 psi r402a is about -21C . How is it possible to measure -26.5c ??? Where do you measure -26.5C ????
    Thanks .
  23. #23
    -150c Club Member
    May 2005
    Northeast, USA
    A matter of my rounding, in the first post the pressure is actually about ~25 psi. I simply rounded it when posting as I couldn't see my own pictures while typing.
    The system is also not running JUST r402a, and the depression of the boiling point is very common with these additives.
    The k-type probe though is on the side of the evaporator, a quarter inch or less from the base.
  24. #24
    Xtreme Mentor
    Aug 2006
    Atlanta
    Quote Originally Posted by n00b 0f l337 View Post
    If its not just r402 then what else are you using and is the load tester frozen solid?
  25. #25
    -150c Club Member
    May 2005
    Northeast, USA
    Tester was iced on the back, my load tester is insulated to get an accurate load reading. That's ice through the block and then quarter inch acetal.
    R290 adds a nice boiling point depression while improving compressor temperatures at the cost of discharge pressure headroom.
