Simple Question, can I run an ATI/AMD card such as a 5870 with a dedicated Nvidia card as physx, or is it not cross-compatible. I've heard yes' and no's from everywhere, So I wouldn't mind a clear answer from some of the big boys on this forum
Yes, you can.
But you need to find the Nvidia hacked driver to make it run.
This thread might be outdated, but has some info.
http://www.xtremesystems.org/forums/...d.php?t=217129
Found something newer.
http://physxinfo.com/news/942/hybrid...in-xp-support/
i7 machine in my sig runs 2xHD5970 and GTX285 for PhysX, its working perfectly with hacked nvidia drivers.
::: Desktop's - Intel *** Intel 2
2 x Xeon E5-2687W *** Intel i7 3930k
EVGA SR-X *** Asus Rampage IV Extreme
96Gb (12x8Gb) G.Skill Trident X DDR3-2400MHz 10-12-12-2N *** 32Gb (8x4Gb) G.Skill Trident X DDR3-2666 10-12-12-2N
3 x Zotac GTX 680 4Gb + EK-FC680 GTX Acetal *** 3 x EVGA GeForce GTX780 + EK Titan XXL Edition waterblocks.
OCZ RevoDrive 3 x4 960Gb *** 4 x Samsung 840 Pro 512Gb
Avermedia LiveGamer HD capture card
Caselabs TX10-D
14 x 4 TB WD RE4 in RAID10+2Spare
4 x Corsair AX1200
::: Basement DataCenter :::
[*] Fibreoptic connection from operators core network
[*] Dell PowerConnect 2848 Ethernet Switch [*] Network Security Devices by Cisco
[*] Dell EqualLogic PS6500E 96Tb iSCSI SAN (40 2Tb Drives + 8 Spare Drives, Raid10+Spare Configuration, 40Tb fail safe storage)
[*] Additional SAN machines with FusionIO ioDrive Octal's (4 total Octals).
[*] 10 x Dual Xeon X5680, 12Gb DDR3, 2x100Gb Vertex 2 Pro Raid1 [*] 4 x Quad Xeon E7-4870, 96Gb DDR3, 2x100Gb Vertex 2 Pro Raid1
[*] Monster UPS unit incase power grid failure backed up by diesel powered generator.
Intel i7 975 Extreme (EK Supreme HF - Nickel)
EVGA Classified 4 Way SLI Motherboard (E762) (EK Water Block)
6GB Corsair Dominator GT 2000Mhz DDR3 Memory
2 x Sapphire ATI Radeon HD 5970 in CrossfireX (EK Water Block - Nickel & EK Blackplate - Nickel)
Mountain Mods Ascension Case
2 x 120GB OCZ Vertex Solid State Drive (Raid 0)
300GB Western Digtal VelociRaptor Hard Drive
2 x Swiftech MCP655 Pumps
2 x EK Bay Spin Reservoirs
3 x 360 Feser Xhanger Radiators
Corsair HX1000X PSU
Dell 3008WFP 30" Monitor
Windows 7 Ultimate 64Bit
Depends on the game and it's implementation of PhysX. In Batman:AA, for example, the answer is hell yes.
Dark Star IV i5 3570K | Asrock Z77 Extreme4 | 8GB Samsung 30nm | GTX 670 FTW 4GB + XSPC Razer 680 | 128GB Samsung 830 Apogee HD White | 140MM UT60/120MM UT45/120MM ST30 | XSPC D5 V2
Thanks heaps fellas just picked up a sapphire 5870 on ebay for 400 AU and going out to get a gtx 240 for physX
use the second link in Piotrsama post. I also used that site when I set mine up a few weeks ago. its the latest hacked driver and you dont have to do all the restart/safe mode bs. plus it is 32 and 64 bit in the same package.
worth it/make a difference? thats dependent on the person implementing it. not many games use it, but it is damn sexy in the ones that do.
I also picked up the 240, works well. currently $65 at newegg with crappy rebate. MSI 1gb but only 128 bit.
