Finally got to make it to CES, big thanks to Fugger for putting on such a great event. Got some benches here that went down and made it to my USB stick.
Don't be deceived, I wasn't actually benching Clarkbar. Cpt. Planet was pouring, Shamino was doing everything else, and I was standing there complaining about stuff and bashing Clarkbar. k|ngp|n's Venom container works as awesome on this setup as it does on Phenom II, the temp stayed stuck at about -185.4, wouldn't budge.
Then we went to chill at Fugger's (and by "chill" I mean chug monsters and bench), and naturally discovered that the Clarkbar had died, as all of them seem to. (I'd use extreme caution with vcore above ~1.8v unless you're below -150, even if it's just for a minute) So due to that unfortunate turn of events, we switched to Mikeguava's E759 X58 Classified and Core i7 975 courtesy of Fugger. Ditched the wussy heatsinks for LN2 on a single 5870. Mikeguava, Shamino and I beat on the rig for a while and ended up with some good results. The MSI 5870 is a screamer, though seems to have memory throttling issues even past 1220, so we left that alone, which was severely detrimental to vantage and 03...:-/ I cold bugged the gpu while trying to save a screenshot of the single 05, so just imagine it in your head. Same as 03 but two clicks higher on CPU.
Dual GPU 3DMark05 49593 - Core i3 540 @ 6516MHz + 2x 5870 @ 1036/1224
Single GPU 3DMark05 46018 - Core i7 975 @ 5660MHz + 1x 5870 @ 1350/1200
Single GPU 3DMark03 108643 - Core i7 975 @ 5597MHz + 1x 5870 @ 1360/1200
Really hope I can make it again next year, between meeting up with everyone, trying to shave down my lap times, and the benching, I wouldn't have missed it for the world.
