Originally Posted by
Vinas
Typically the loop should go Res -> Pump -> rad -> CPU but I doubt the way you have it setup is adding much heat load. Unless you have an iwaki pump or a ac120 pump that is direct drive, because those can add quite a bit of heat load. Still you would experience some temp fluctuations so... Maybe it is stuck? I had an e8400 that would never drop below 20c, even when the temp probe read -15c. So stuck sensors can happen although my hunch is that your TJmax is being read wrong.
