im wondering if anyone knows the max temp`s the southbrigde and northbridge chipset is aloud to reach .. beacause at the moment there reaching 50c when i use prime 95 to oc my q6600
Gaming Rig
Intel Q6600 Oc 3.2ghz
4gb Ocz ddr 2 Ram
corsair h50 Cpu Cooler
Asus Maximus ii Formula X38
Samsung Spin Point 320gb
Ocz 60Gb Ssd Drive O/S
Antec 1200 Gamers Case
Gigabyte 720 Watt Psu
Windows 7 64
50C For the chipset is fine. Im not sure what the Asus faithful have to say about the max temperature but 50c is well within a normal spec for a chipset. If it starts going above 70c than you might want to stop pushing the NB\SB voltage through![]()
Intel i7 920 D0 4.2ghz 24/7 Swftech GTZ\Duniek Wide CU\AL
Evga E760 Classified Stock Air
XFX Radeon 5870 Stock Air (WB Soon)
Corsair HX1000
OCZ Platinum 6GB
Antec 1200
Vantage: 22834
CPU-Z: 5ghz
dont think i has reached 70C so thats ok .. havent touch none of the voltage .. new to overclocking
Gaming Rig
4gb Ocz ddr 2 Ram
Windows 7 64
50C for nb/sb isn't high temperature![]()
Intel Core i7 3770K Costa Rica 4.5GHz 1.232v + Noctua Nh-D14 \\ ASRock Z77 Fatal1ty Professional \\ G.Skill RipjawsX 2x4GB 2133MHz 9-10-9-18 1T 1.55v \\ Gigabyte GTX 670 Windforce3 2GB @1254/7800
2x Corsair Neutron GTX 240GB + OCZ Vertex 4 128GB \\ Edifier R2600 \\ Creative X-Fi Titanium \\ Cooler Master HAF-X \\ Seasonic X-760 80+ Gold \\ BenQ XL2420T
