+ Reply to Thread
Results 1 to 3 of 3
Thread: Can't run particular WUs.
    BANNED!!!!!!!!!!! lkiller123's Avatar
    Dec 2008
    Los Angeles/Hong Kong
    20
    Finally made my brother's build stable now, I was going to check out how BOINC was doing.
    I found out that some WUs was suspended before they were finished. Under the status they were marked as "Waiting to run." I tried suspending some other WUs to make those original works run, but it won't work. Now I have a whole cluster of unfinished WUs "Waiting to Run." I waited for one WU to finish, but BOINC will just start to run another fresh work unit.
    What do I do?
    Xtreme crazy bastid D_A's Avatar
    Apr 2007
    In the middle of an Auz fire zone.
    0
    Tell the client not to get any more work and they should clear. Sometimes that happens when other units get sent out with short deadlines. This gives them a higher priority and the client will preempt existing work to get through the urgent ones first.
    Xtreme Cruncher Snow Crash's Avatar
    Mar 2009
    kingston.ma
    40
    Typically you only run into this is yopu have a fairly large cache and then either the WU estimates are way off and start correcting themsleves or you turned the machine off for a while so BOINC manager again is trying to adjust to new parameters and thinks it is in trouble. If the projects I am running on a machiner are ZR (zero redundancy) like HFCC and FAAH then I go with a .35 day cache and if any other projects I go with 3 days. Anything more than that and you are just slowing everyone else down :-)
+ Reply to Thread
