could anyone here build a high powered liquid cooled single stage or medium powered dual stage for approximately the same price as this:
http://www.performance-pcs.com/catal...ducts_id=22128
and in the same form factor
Dual E5530's @ 3.7ghz Watercooled
Evga SR-2
GTX 480 TRI-SLI Waterchilled
24Gb samsung 30nm HYK0
Coolermaster 1200w PSU
Originally Posted by Some guy on a xbox forum
Are you asking if it is possible or if someone can do it for you? If it is the former I would say yes for the liquid cooled single stage in that form factor but no to a two stage in that form factor. If it is the latter I would have to politely direct you to the forum policies rule 5A.
Actually it might be possible to make a low power cascade in the form factor, but at that price point? No way.
Two rotaries crammed in a line, plate HX side by side, one insulated, one cooling the first stage. No oil sep or something really small and home made, and work from there. Could strap a triple radiator to it possibly, on the top or off the back, or external and off to the side; even fit the pump in there nice and tight if your good about it.
The trick is going to be air cooling on the rotarys.
Originally Posted by Movieman
Never empower an idiot with a response....
http://en.wikipedia.org/wiki/Troll_%28Internet%29
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
You sure on that? I've heard nothing but shipping issues and jostled compressors mixed with crappy controllers.
I've had to fix 5 of them and I've only ever heard of people that owned those said 5 other then one that was reviewed by Coolarer.
A few people here and on OCN, although they were under warranty, the user had to pay the shipping cost back for the unit; an international cost. And that costed as much as a recharge.
Received and responded, that's your imperative Scott.
piotress recently made a water cooled single stage for a customer.
http://www.xtremesystems.org/forums/...d.php?t=233163
Phenom II 1090t BE @ 3.8
Mushkin 2x 4gb 1333
Gigabyte 890fxa-ud5
EVGA GTX 285 SC
OCZ agility 3 60gb
WesternDigitial 1Tb storage
SilverStone Strider 750w modular
CoolerMaster Haf 912
Corsair H70
Funny you ask because I am the only authorized/trained CoolerExpress repair tech currently residing in the US
I work part time for CoolerExpress and have seen only 1 repair unit in the last 2 months since they hired me. That one repair was very minor and had absolutely nothing to do with poor engineering.
CE units are very high quality and put together much better than the old MachI/MachII units were. The wiring harness is top notch and so is the controller. They use steel suction lines, high quality condensers, sturdy steel cases and strong compressors.
Evga SR-2
I wouldn't use a 12k btu rotoYou recently said in a different topic that you can not do this as the heat output and cooling needed for one rotary a 12k BTU it was out weight a 120.3 under water cooling.
That's good to know that they fixed there first revisions issues.Funny you ask because I am the only authorized/trained CoolerExpress repair tech currently residing in the US
For something like this I would use two 5k btu to 7k btu compressors, nothing larger. This is like a mini cascade I rebuilt, both were "1/2 hp" compressors and held a decent load in the -90C to -70C range.
I can't remember ... was that the mini cascade that fit into a case that sat side by side with the computer ?
Mr.Ron McCall, please contact me, Becky at: coolerexpress@seed.net.tw
