good job, almost done
That pic of the block on the mobo is beautiful!
I very much like this.
Those radiators look spectacular!
thx guys. i still order some parts next week hope i can finish this in this month.
GPU's look insane. Forgive my laziness, what motherboard is that?
its the EVGA p55 FTW200
cards are gtx275
Damn, doesn't support 1366 or I'd get it. One of the sexiest mobo's I've ever seen.
haha man i have my reservoir just in the exact same place as you, with candy red coolant too It helps there are 2 holes on the MB plate that are just perfect for this...
For the cable management: you have no problems putting on the door panel ? I found out there is very little room back there...
You dropped completely the upper horizontal strut ? Or you plan to put it back on eventually ?
The CPU and GPU blocks look killer mate!! There's bling flying around everywhere in there
jup but i put new holes in there. as u can see there is no reservoir holders its magic
the case will still be on this status. the only changes wich comes is new passiv coolers ( swiftech gtx275 ) and maybe a ramcooler but im not sure. and of course singleslot for the grafikcard.
i like thise cute looking chrom in there. its not to much i think. i was just thinking about to polish the tray and the other aluminum parts in this case but i still let it as it is whats about ure bling bling ? still go forward ?
I think you may need to change the title to "Whuzabi's Wild One" ... it looks like the project grows every day (a good thing!). Coming together nicely.
gg shazza
the problem is that i have so much ideas that i would do in this rig but its not possible. so i try to do not to much because if i had the real capacity i would do more an bigger things
@callen
still want to see some fresh pics
So digging those blocks, whuz!
Can't wait for you to bring on the bling
[SIGPIC][/SIGPIC]
Now Playing
black freighter: i7 920 | evga classified | mm extended ascension pedestal | 2 x 300gb vraps
dead men tell no tales build: q9770 | asus striker 2 extreme | 2x4gb ddr3 ocz reaper | 2 x gtx 280 oc2 | 2x 300gb vraps | mm ufo-cyo | pcp&c 1200W
Excellent work whuzabi.
I like the shade of red coolant you have used.
The reflection of the coolant will look outstanding when it's all polished up.
Could you please let me know where you got the aluminium heat sinks from.
@ktiger
u mean the VGA Chip Heatsinks ?
@cpt
no more bling bling.
maybe a ram cooler not more ( i hope so )
looks good man
Is this the finished version though?
nononono thats not finished.
i need new PCIe cables
tubing will change his way ( im just thining about how i can change the long way to the cpu )
there will come a pcie fan bracket from lianli like the BS-03
a little pic for the wait
hello i´m still alive
Damn that's nice ............ I've never had the balls to go tubing no clamp on barb.
MagisD
____________________________
Lurker, Dreamer, Planner, Noob
6 Quad rads 1 case Maybe I went a little overboard....Overkill Cube
Duality: Q9550 - P5Q Deluxe - 8GB OCZ - HD5850 - 4,64TB WD - HX650 - X-fi - Aquaero 4 - Lian Li V1000b II Plus @Dual loops watercooling
Loop 1 => DDC18w w/ EK X-top V2 - EK Supreme HF - EK FC5850 - PA120.3 - Multires 150
Loop 2 => DDC18w w/ EK X-top V2 - PA120.1 - MIPS mosfet 1&2 - mips NB - Mips Ramfreezer 4 - MIPS SB - Multires 150
Ya but I'm one of those that something falls out a window it falls just when I'm walking under it. So I'm never going clampless.
Sent from my X10a using Tapatalk
MagisD
the fitting is 1/2"
and the tubing is a tygon 5/8" ( 15,9/11,1mm )
and i got no window
