I'm trying to pick the best value wolfdale-based (read: Core2, 45nm, dual-core w/6MB or 3MB L2) C2D or Xeon CPU.
One that OC's nicely & allows me to get the FSB/CS up to the top-end CPU's when needed.
But also one that under-volts reliably on stock settings or even slightly above stock! (I have heard of this)
Are there certain models/batches that are better suited for this or is it purely 'hit & miss"?
Has anyone had good experiences doing what I'm wanting, if so what did you go for and on what motherboard?
For motherboards I'm considering GA-EG45M-UD2H or P5Q-EM.
I'm leaning more towards the former....
What memory do you recommend I go with?
DDR2-1066 isn't overkill if I do intend to OC markedly on occasion right?
All this is is for a MythTV/Media front-end, hence the reason why I want to be uc/undervolted or both most times.
Thanks all!
P.S.
I'm well aware of the load that VDPAU takes away....
And I understand that when idle EIST/C1E will ensure power draw is minimised 90% of the time.
But I still want to experiment
