Results 1 to 15 of 15
Thread: Cosmos 1000 side panel Asus logo
    Oct 2009
    I plan to cut a window of some sort (acrylic or mesh) and i have been playing around with some ideas on photoshop, to see what they would turn out like.
    This is one in particular i liked, but i was wondering if the cut would make the whole side panel too weak around the center point.
    also let me know what you think, or if you have any suggestions.
    Cheers
    Patience is the only talent.
    Sep 2006
    North East UK
    You might want to consider keeping the cuts inside the re-enforcement section on the reverse side of the panel.
    Oct 2009
    cheers I know, it will be within the bourdaries of the outside layer of screws, this is just a mock up for now.
    Oct 2009
    Or theres the i7 version
    Jan 2009
    Chandler, Arizona
    I like it. Very sleek looking!
    -trekie86
    Antec 900 Black
    Rosewill 600W RP600V2-S-SL
    Gigabyte EP45-UD3P Rev 1.0
    Intel E8500 @ 3.8 GHz
    2 x 2 GB GSkill PC6400
    EVGA Geforce GTX 260 Core 216 SSC 55nm
    EVGA 8800GTS PhysX
    640 GB WD HDD 7200 RPM
    Quote Originally Posted by dengyong View Post
    Started life as a FTW and ended up as a WTF.
    Oct 2009
    Cheers trekie
    if anyone else has an idea of a panel window they want, let me know, and give me a pic of what case/panel you want it on, and ill try and mock it up best i can for you
    Oct 2008
    EU
    I like i7 version too.
    Intel Q9550 E0
    Prolimatech Megahalems + Xigmatek XLF-1253
    Asus HD4870 512MB 810/1000mhz
    A-data 2x2GB OverClock Extreme Edition 1066+
    ASUS P5Q Deluxe 2301
    CHIEFTEC 560W (CFT-560-A12S)
    Maxtor DaimondMax STM3500320AS
    CM HAF 922
    Samsung T220 1680x1050
    Vista x86 SP2
    Jan 2008
    I don't get the whole thing with dudes putting company logos on their boxes unless those companies are paying them to advertise. Why not put something that's cool or meaningful to YOU? Are you fishing for sponsorship with these threads? Is that what I'm missing? No offense, just curious.
    Modded Cosmos. | Maximus II Formula. Bios 1307| 2x2 Mushkin XP ASCENT 8500 | Q9550-E0- 4.10 + TRUE | Visiontek HD4870X2 | LN32A550 1920x1080 | X-FI Extreme Gamer | Z5300E | G15v.1 | G7 | MX518 | Corsair HX1000 | X25-MG2 80G | 5xHDD
    ____________________________________
    Quote Originally Posted by saaya View Post
    most people dont care about opencl, physix, folding at home and direct compute... they want cool explosions and things blowing up and boobs jumping around realistically... .
    Oct 2009
    Nah its just a mock up really :P I'm just looking for like, something that looks good, and that i7 logo looks sleek and professional, which i why i like it. If i find a simple enough graphic then i'll put it on. I don't beleive in sponsorship to be honest, but then again im not after the money/support, I like to know I can do things off my own back, thats the way i've always managed Check back here later today, ill have a sketchup idea of what i may have on the front panel, it was a clock design i saw at artec laser cutting while i was getting a quote
    Jan 2008
    I like the mesh thing, just not company logos, and not on the side - it allows noise to get out. But the front panel is a cool and harmless place for something like that. I was getting bored with the front of my cosmos as well. So lets see what you're up to with this thing.
    Oct 2009
    "Carbon fibre" texture vinyl backing, blue anodized brushed aluminium strip, plain aluminium brushed strip, black brushed parallelogram ontop of 6mm thick clear acrylic (same shape) with LED's embedded in the acrylic, where you see the holes. Used red for this example as it makes it more defined.
    Where I'm up to atm with the case it getting an internal support for my radiator cut out, getting it done this morning, and while im there i may get the front panel design done to, if the total cost stays under 200.
    Will be cut out in around 5 hours, and ill put pics up here and on my project worklog Industrial Revolution.
    Nov 2007
    Cincinnati, Ohio
    If you are doing an i7 logo, why not actually use the i7 logo, not just a random font I and 7? Not quite sure what those blue and silver things are on the front panel, but I assume you don't need fresh air if its watercooled. Love those cases though.
    Aaron___________________________Wife________________________ HTPC
    intel i7 2600k_____________________AMD5000+ BE @ 3ghz___________AMD4850+ BE @ 2.5ghz
    stock cooling______________________CM Vortex P912_______________ Foxconn A7GM-S 780G
    AsRock Extreme 4_________________ GB GA-MA78GM-S2H 780G_______OCZ SLI 2gb PC6400
    4gb 1600 DDR3___________________ OCZ Plat 2GB PC6400___________Avermedia A180 HDTV tuner
    MSI 48901gb 950/999______________Tt Toughpower 600w___________ Saphire 4830
    Corsair HX620____________________ inwin allure case___________ ___ Coolmax 480w
    NZXT 410 Gunmetal________________Acer 23" 1080p________________ LiteOn BD player
    X2gen 22" WS
    ________________ ________________________________ nMediaPC 1000B case
    Oct 2009
    I don't like the original i7 logo haha, but thats me. my style is "simple" so usually less bends/curves but more abstract/agressive. same with painting. Yeah it is watercooled, and I might change that design around a little bit, put some mesh in there somewhere, because i need a front opening at least for air to get in. Yeah I love the cosmos 1000's also, I was going to go with a new Obsidian 800D but i thought i'd give modding a shot . I'm off to get it laser cut now, pics in about an hour
    May 2004
    AB. Canada
    OK say you go with an ASUS logo. the MB dies and you get an EVGA one.
    that would be kinda odd.
    or the I7, what will you do when it is time to upgrade to the I8?
    buy a new side pannel and put I8 on it? then people will start wondering what did you eat? "I ate"
    "Great spirits have always encountered violent opposition from mediocre minds" - (Einstein)
    Oct 2009
    i8? isn't the next series i9? lol anyway, Well i may get the letters ICON cut out, as that is my favoutire DAW desk to use, but just throwing out ideas really.
    Note on the top panel, i've submitted it but it is going to be a few days before they can cut it, due to back listing i got excited for nothing
