Wondering if you have a radiator, and the top fan is pushing out 50cfm and the bottom fan is pushing in 70cfm, how many cfms come out of the rad? 50 +70? 50? or 70?
Thanks.
My guess is 70?
Thanks.
My guess is 70?
Motherboard: EVGA Classified 759
CPU: Intel 920 D0 2.66 @ 3.8ghz
Ram: 6gb 1600 DDR3 7-7-7-20 Corsair Dominators
PSU: PC Power Cooling 1200 ESA
Audio: SB X-Fi Titanium
Video: Trifire XFX 6970
Harddrives: WD3000HLFSx2+ OCZ 120G Vertex SSD
Cooling: HK 3.0 - XPSC360 Rad - MCP655 pump
It depends on how much restriction you get from the radiator. The fan is not a magic machine always producing the same airflow regardless of resistance. Increased flow resistance reduces flow, putting two fans in series pretty much ads the two fan curves, increasing static pressure and hence flow.
It is impossible to have different air flow though two fans in series, unless you somehow removes part of the airflow between the fans.
"I don't have a masters degree, but even I know that mixing water and electronics is a stupid thing to do."
My girlfriend.
"It's easy to get sideways at first thinking there is ONE BEST product for each area of water cooling. But, that's not always the case - depends on your exact setup and needs."
shazza
AFAIK u shouldn't use different fans on one side then the other, they should b the same fans on both sides of the rad, also putting 2 fans in series doesn't increase air flow only pressure like has been said, if there is a high restriction case then 2 fans stacked WOULD give more CFM then a single fan but only because it has more pressure not because it is moving more air vs one fan, understand?
Dragon
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
radiator normally cut ~50% cfm on passing
place your hand near the below fan (intake) ... if you felt the some slight air is leaking out from the circular sides, then there's air restriction i.e thick grills or positive pressure
if you're a smoker, could always smoke a cig, blow it to the balloon and release it to see the air movement ..
Well lets say the two fans are in a pipe with no restriction? I read that fans are like pumps and that two fans in a pipe will blow out as much cfms that the highest rated fan can push out ??? I think.
On my rad I have three pairs of fans, top and bottom, where the bottom fans are more powerful. Its not ideal but I ran out of fans and thats the best that I had...
