I know there's already a couple of threads on modding these cards but it seems that there's a lot of non ref PCB's out there. Compared to the other guides on here, the only IC that I have in common with others is the vmem IC. The other IC's I have looked up on my card don't have FB pins. So if somebody can help me, I'd really appreciate it
These are the two different type of ICs I have on the back of my card.
uP6101
http://www.upi-semi.com/ProductFiles..._DataSheet.pdf
PM25LV512A
http://www.chingistek.com/resource_c...040%20v3.5.pdf
RT9173C
http://pdf1.alldatasheet.com/datashe...K/RT9173C.html
uP6101 is the IC in the top left corner, RT9173C are the bottom two towards the bottom right corner and PM25LV512A is the one top of the bottom two.
