Results 1 to 7 of 7
Thread: Move method in php
    Jul 2008
    Somewhere in FL
    Move method in php
    what is move method in CLASS?
    I tried to search in google but no luck:
    "Create a move method in the Shape class that accepts two values. These values are added to x and y attributes to simulate moving the shape."
    this is the code I got so far (please fix me if something is wrong with this code):
    class shape {
    private $name;
    private $x;
    private $y;
    function __construct($x , $y) {
    $this->X = $x;
    $this->y = $y;
    public function setName($name) {
    $this-> name = $name ;
    public function getName() {
    return $this-> name ;
    public function setX($x) {
    $this-> x = $x ;
    public function getX(){
    return $this-> x ;
    public function setY($y){
    $this-> Y = $y;
    public function getY(){
    return $this-> Y ;
    thanks
    hale
    Current system:
    Corsair O8D LiquidAir
    EVGA X58 LE | Intel Core i7 920 | EVGA GTX 285 (waiting for Kepler)| X-Fi Fatal1ty | 1TB (SEAGATE), 2x150GB RAPTOR (raid 0) | TX950w
    RUN ON AIR
    My Flickr
    Jul 2008
    Somewhere in FL
    here are some update. I have to create a Shape.php, Circle.php, and Square.php and yes I did, here is the code: However, I cannot get them run for some reason ( I still need MOVE METHOD)
    Testing code:
    require_once('Shape.php');
    require_once('Circle.php');
    require_once('Square.php');
    $myCircle = new Circle("aCircle", 2, 3, 5);
    $mySquare = new Square("aSquare", 0, 0, 4);
    echo $mySquare->getName();
    echo "<br />";
    echo "Area of square is ";
    echo $mySquare->area();
    echo "<br />";
    $mySquare-> move(23, 45);
    echo "Position of square is x = ";
    echo $mySquare->getX();
    echo " y = ";
    echo $mySquare->getY();
    $mySquare->setSide(6);
    echo "<br />";
    echo "<br />";
    echo $myCircle->getName();
    echo "<br />";
    echo "Area of circle is ";
    echo $myCircle->area();
    echo "<br />";
    $myCircle->move(15, 20);
    echo "Position of circle is x = ";
    echo $myCircle->getX();
    echo " y = ";
    echo $myCircle->getY();
    $myCircle->setRadius(-2);
    echo "<br />";
    Shape:
    class Shape {
    private $name;
    private $X;
    private $Y;
    function move ($X,$Y) {
    return $this->X;
    return $this->Y;
    function __construct($x,$y) {
    $this->X = $x;
    $this->Y = $y;
    public function setX($X) {
    $this-> name = $X ;
    public function getX() {
    return $this-> X ;
    public function setY($Y) {
    $this-> name = $Y;
    public function getY() {
    return $this-> Y ;
    Circle:
    require_once ('Shape.php');
    class Circle extends Shape {
    private $radius;
    function __construct($name,$x,$y,$radius) {
    Shape::__construct($name,$x,$y);
    $this->radius = $radius;
    public function setradius($radius) {
    if(is_numeric($radius) && $radius > 0 ) {
    if(is_numeric($radius) && $radius < 0 ) {
    $this->radius = 0;
    public function getradius($radius) {
    return $this-> radius ;
    function getarea() {
    return 3.14159 * $this-> radius * $this-> radius;
    echo $myCircle->getradius();
    echo "<br />";
    Square:
    class Square extends Shape {
    private $side;
    function __construct($name,$x,$y,$side) {
    $this->side = $side;
    public function setSide($side) {
    if(is_numeric($side) && $side > 0 ) {
    if(is_numeric($side) && $side < 0 ) {
    $this->side = 0;
    public function getSide($side) {
    return $this-> side ;
    return $this-> side * $this-> side;
    echo $mySquare->getSide();
    echo "<br />";
    Current system:
    RUN ON AIR
    My Flickr
    Oct 2007
    Mid UK. Lift a few rocks, eventually you will find me.
    The braces in your code are mismatched, getradius and getarea are outside your circle class, getside and getarea are outside your square class.
    You do not have the php delimiters set up properly there is no opening "<? php" in the code only the closing "?>"
    As for a move function, what you need to do is change the x,y co-ordinates for the shapes. You can write functions that either set new x,y co-ordinates and discard the old co-ordinates or add values to the existing x,y co-ordinates. Setting new x,y co-ordinates would be the easiest approach, however if the calling code can only provide changes in co-ordinates and not absolute co-ordinates simply setting new co-ordinates will not work.
    I would write a function that did both;replace x,y with new values or change x,y via addition. You could pass a flag(1 or zero, true or false) to this function to control which approach is used within the function.
    something like this
    function move(newX, newY, flag) {
    if flag { //replace old with new co-ordinates
    x= newX;
    y=newY;
    else //change existing co-ordinates;negative values of newX or newY would be the equivalent of moving the co-ordinates left or down)
    x+=newX;
    y+=newY;
    Did you get your temp conversion code working?
    Fun Box: Asus P8Z68-V GEN3++Corsair AX850++i5 2500k@4.5Ghz-1.272v++Corsair A50++2x8Gb Corsair Vengeance++MSI R7970 Lightning++Audigy2 Plat-EX++TBS 6280 DVB-T2 tuner++256Gb OCZ Vertex 4.500Gb Caviar Black.500Gb Seagate Barracuda++Sony AD7240s++Lian-Li PC-60++Linux Mint/Win 7++Asus P238Q
    Work Box: Gigabyte H61MA-DV3++Corsair HX620++i5 3450@stock++2x8Gb Corsair Vengeance++120Gb OCZ Agility 3++Linux Mint
    Quantum theory in a nutshell: It's so small we don't know where it is, it could be here, it could be there.
    Just 'cos it's legal don't make it right.
    Jul 2008
    Somewhere in FL
    I left the Function Temperature assign since I need to figure out how it works. However, this project is more interesting:
    here the three separate files and A index.php for testing these three files:
    1. Shape:
    <?php
    class Shape {
    protected $name;
    protected $x;
    protected $y;
    $this->x = $x;
    $this->y = $y;
    $this-> name = $x ;
    return $this-> x ;
    public function setY($y) {
    $this-> name = $y;
    return $this-> y ;
    public function move($x, $y) {
    $this->x += $x;
    $this->y += $y;
    2. Circle:
    <?php
    private $radius;
    else {
    $this->radius = 0;
    function area($radius) {
    return 3.14159 * $this->radius * $this->radius;
    3. Square:
    <?php
    private $side;
    public function __construct($name, $x, $y, $side) {
    $this->name = $name;
    $this->x = $x;
    $this->y = $y;
    else {
    $this->side = 0;
    function area($side) {
    4. Testing index.php Code:
    <?php
    echo "<br />";
    echo "<br />";
    echo " y = ";
    echo "<br />";
    echo "<br />";
    echo "<br />";
    echo "<br />";
    echo " y = ";
    $myCircle->setRadius(3);
    echo "<br />";
    Current system:
    RUN ON AIR
    My Flickr
    Oct 2007
    I have been busy and without Internet access, so I appologise for the delay. I expect you have worked out by now that that your area functions within each shape class require an argument "$side" and when you are calling the area functions from index.php you are not sending that argument and you really don't need to as area can be calculated from the parameters you used to create the shape.
    Come on I aint gonna fix anything for you I will help you to fix it yourself though.
    I put your code on my LAMP server and this was displayed in my browser when I opened index.php
    aSquare
    Area of square is 16
    Position of square is x = 23 y = 45
    Area of square is 36
    Area of circle is 78.53975
    Position of circle is x = 15 y = 22
    Area of circle is 28.27431
    see it in action: http://www.propergander.org.uk/shapetest/index.php
    Running from the command line this was the output:
    user@server:/var/www/shapetest$ php index.php
    aSquare<br />Area of square is
    Warning: Missing argument 1 for Square::area(), called in /var/www/shapetest/index.php on line 13 and defined in /var/www/shapetest/Square.php on line 28
    16<br />Position of square is x = 23 y = 45<br />Area of square is
    Warning: Missing argument 1 for Square::area(), called in /var/www/shapetest/index.php on line 24 and defined in /var/www/shapetest/Square.php on line 28
    36<br /><br />Area of circle is
    Warning: Missing argument 1 for Circle::area(), called in /var/www/shapetest/index.php on line 29 and defined in /var/www/shapetest/Circle.php on line 28
    78.53975<br />Position of circle is x = 15 y = 22<br />Area of circle is
    Warning: Missing argument 1 for Circle::area(), called in /var/www/shapetest/index.php on line 39 and defined in /var/www/shapetest/Circle.php on line 28
    28.27431
    Sorry I took so long to reply. Out of curiosity what OS are you doing your coding on?
    ps your shape class does not have the closing "?>" either
    Jul 2008
    Somewhere in FL
    thanks I just got my problem solved from my instructor . I was missing the input for the Area->created error
    Current system:
    RUN ON AIR
    My Flickr
    Oct 2007
    np, good luck
