X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 2 of 2
Thread: Blackops and TW3x4G1333C9 issue
    Dec 2009
    Hi all.
    Wonder if anyone can help me out.
    Just assembled my pc with Q8200 cpu and TW3x4G1333C9 ram
    With memtest, either stick of ram in any slot is fine no errors 100%
    The problem Im seeing is when I put both sticks of ram into the board.
    Memtest fails and system reboots 10 secs into the test. Ive tried this in both single and dual channel configuration.
    Im running with default or Optimized defaults in Bios, The only change I've made is to update Bios to the latest version.
    When the system fails more often than not its showing code 54 on the debug led. Reading this forum suggests ram setup..
    Ive installed Vista 64 using just one stick of ram and the system seems rock solid. No errors, BSOD nothing.
    Any advice would be greatly appreciated.
    Dec 2009
    Just an update.
    Think Ive finally found the cause of my woes.
    Been running this pc with only one stick of ram in it for the past 2 days with no issues what so ever and decided to try the other stick on its own in the same slot.
    Within 20 mins the pc shut down and would not reboot. error 54 on the debug LED. Looks like a faulty ram module all along.
    Im back to the original ram module now and all is well again.
    Really strange that I have been able to memtest the "faulty" module and it passes..never had an intermitant fault with a pc componant before, generally they work or they dont for me.
    Everyday is a school day.
