Looking to help build a socket 1156 with the i7 860 2.8ghz (3.46ghz turbo mode) gaming system for a friend, with either a GTX 275 or possibly ATI 5850 if they feel they want a DX-11 card (They seem like the best values right now)
I have been looking at the ASUS P7P55 LX (119$)
http://www.newegg.com/Product/Produc...82E16813131604
Or the GIGABYTE GA-P55-UD3R (139$)
http://www.newegg.com/Product/Produc...82E16813128401
I am trying to keep the cost under 150-175$ or so, but that COULD go up if it's truely worth it...reliabilty is the most important thing I am looking for.
SLI and XFIRE support are not needed, but I would not complain if it had them.
I doubt my friend will Overclock it, unless its with software (I built a Gigabyte UD3 Q9550 775 system for a friend and used the software to run it at 3.6ghz, worked like a champ!)
So max OC is not a top priority either, but good software OC'ing would be nice (Had not had much luck with it in the past on my 775 Asus boards or on my DS-3, but all were great in manual OC'ing)
Also, Zalman seems to have one of the top coolers for socket 1156, but it's 75$, are there any other solutions that will still be adequate for stock or mild OC's that are 50$ or so? Otherwise I imagine the stock intel cooler would do just fine for stock clocks, I will tell them to save there money.
Any comments or recomendations would be appreciated on any of the hardware, the budget is roughly 1000$ (+or-200)
I have a wish list, but even this is open to debate.
Intel Core i7-860 Lynnfield 2.8GHz
ASUS P7P55 LX LGA 1156 Intel P55
SAPPHIRE 100282SR Radeon HD 5850 1GB
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire
CORSAIR XMS3 4GB (2 x 2GB)
Win7
