very nice ghost pretty awesome job. i have a question for you one fittings did you use in the midplate to hook up the other fittings?
Thanks all for you comments
These are what I used http://www.sidewindercomputers.com/big14shsicat.html
Intel I7 940 @4Ghz - water cooled
Corsair Domitator 12800 12GB
Asus Rampage II Extreme
HIS ATI HD 4870X2 - water cooled
Creative X-fi Xtreme Gamer Fatal1ty
Enermax Galaxy 1000W
3x Samsung F1 500GB HDD
OCZ Vertex 120GB
TJ07 Murdermod
LG W3000H 30" Monitor
Vista Home Premium x64
Great job all round there mate
But I bet you're gonna have a hard time even changing your HDD cause it seems like everything is all tied up together
Nevertheless.....Great build
Ghost.. Can you tell me about your fan controller.. which one did you buy and where and how did you mount it?
OMG!!! O.O It's one of the best TJ07 builds ever!! Just astonishing MDPC for sure
Don't you think about window?
OCZ Vertex 120GB
TJ07 Murdermod
Great build!
Seeing the powdercoated parts of the TJ-07 and the two rads in the basement brings back old memories...
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
The fan controller is a Zalman MFC-1, repainted and with the LED's shorted out. Controls the 5 Fans in the lower section and also powers the lighting and murdermod logo. This is how it looked originally:
http://www.sanalmarketim.com/_prod/_...AN_ZM-MFC1.jpg
Think its been discontinued a long time now but there might be some on the 'bay. I drilled 4 mounting holes above the top outer bay slot, as its only a few cm deep the curve on the top of the case doesn't effect it. Also there's plenty of room in there to hide the cables.
You can see the mounting holes in this pic:
http://i24.photobucket.com/albums/c3...d/DSC00150.jpg
Thanks , I'm not sure its that good I kinda like just having the top to view into it, the cathode lights the top well. I don't bother screwing up that side panel so I can just pull the side off to look at it. Makes the whole case look a little more sleek I think.
Thanks, yeah I've been planning a build in a TJ-07 for ages and after seeing the murdermods builds others had done I knew it was the case for me.
OCZ Vertex 120GB
TJ07 Murdermod
That's a nice clean build. I love the tubing and the fittings. I think, that's what I'll use for my build.
hey ghost, great build! I was wondering how much was the powdercoating for all those parts?
also what are those scythe blocks called for the hard drives?
The powdercoating was £40 from my local paintshop.
Scythe blocks are HIMURO got them from here:
http://www.scan.co.uk/Products/Scyth...d-Drive-Cooler
OCZ Vertex 120GB
TJ07 Murdermod
Nice build, very clean, and good job on squeezing everything in.
I've been wanting save space and clear out my dual bay res for a while. I thought about getting the ddc+xspc res top, but it means I need to get rid of my D5 =(, but after I saw your res+d5 combo you saved me! That was very clever what you did d5+ek+res. So is that an EK res 250 you used and what male to male fitting is that?
Cooler Master Haf X
i5 3750k
Asrock Xtreme 4
660 Ti
Cheers
I used this for connecting the pump to the res
http://www.chilledpc.co.uk/shop/prod...roducts_id=902
This is the bitspower ones I was going to use:
http://www.sidewindercomputers.com/bishsimatoma.html
It works well just gotta watch the wirlpool going if there's to much flow sucking the air straight back into the loop.
OCZ Vertex 120GB
TJ07 Murdermod
Very well done, Ghost. I like the photos of your Mountain Mods build too - but I imagine the TJ-07 fits better if you have limited space.
Thanks, mountain mods are nice cases but I had done everything I wanted with that case so needed a new challenge. Really liked what you've done with yours
I had the blocks nickel plated:
http://www.chilledpc.co.uk/shop/prod...roducts_id=998
I didn't do it myself so I'm not sure what the process was for doing it.
OCZ Vertex 120GB
TJ07 Murdermod
OCZ Vertex 120GB
TJ07 Murdermod
Very Nice!
Are the D5's mounted to anything or just resting on the mid plate?
Cheers
Project: Heart of Darkness
EVGA 750i FTW, E8400, EVGA GTX 470, Corsair Dominator 8500 2 x 2048, Corsair HX1000, Antec P180B, Samsung 2433BW Plus, Windows 7 Home Premium x64
