thanks
Aber merk dir eins : Das hier ist nicht der Super Spam Thread
thanks
You need a sleeved PSU or someone who sleeves your PSU ?
Send me a PM
"Sanded" gives the image of being more precise, using sand paper. "Grinded" is more rough, using power tools. Very nice build though.
thank you for the explanation
and thank you for the nice words
Send me a PM
I would like to give a big Thank to all the IT web coder's at Google, for with out you, we wouldn't have the pleasure of fhantastic.
Excellent work champ, looking forward to your next update.
The CPU Cooler Mounting is finished :
Send me a PM
what is with the empty slots of ram ?
Another two ram modules will come
Nice ferhan!
i´m not sure paul
But i´m sure the sleeving is completed to 90%
One picture of the dark side
Send me a PM
nice work ferhan : )
looking really good fhan. i have a new respect for that case.
- Silverstone FT-01B
- Corsair HX620
- DFI LanParty DK 790FX-M2RS
- AMD X2 6400+ BE w/ Thermalright Ultima 90 @ 3.2
- 2 x 1 GB G.Skill DDR800(4-4-4-12)
- 2 x 1 GB Corsair XMS2 Dominator(4-4-4-12)
- BFG Tech 9800GTX(stock cooling for now)
- 2 - 250GB Seagate SATA
Cabling and sleeving look excellent fhantastic.
What have you used to conect the P clips?
Do you feel you may need some rubber around the edge of the cut outs in the MoBo, where the cableing goes through?
I do like the fact that you have taken the time to show us the "Dark side" of your case, it's very well done, you should be proud of your self mate.
please show us your new case feets ferhan
i never use rubber for the edges
I have used m3 screws for the p -clip + snap caps
i think i can be proud of the dark side
Thank you ^^
ok ok i show you the new case feet
Send me a PM
sweet ♥_♥
test test test
Send me a PM
last pic rocks da house
what are those "caps" on the screws ? link ?
Worklog 1: ★★★ Project: Icebreaker ★★★
Bundymania @Facebook: Come and join me now
Triple (360) Radiator Roundup with 22 Rads !
Swiftech MCP35X Pump Review /// Roundup -> Bay Reservoirs & Laing Tops !
Review: 22 CPU Waterblocks // Review: 4x Tecnofront Reservoirs !
Quad Radiator Roundup - 11 Rads tested
Update: Mora 2 / Mora 3 / Phobya 1080 Xtreme & Supernova 1260
Tubing Comparison: 3/8" & 5/8" from Masterkleer, Primochill, Tygon, Kooolance, Nalgene
that are snap caps
Send me a PM
nice pics! what tubing do you use?
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
wow.. very niiice
It´s Tygon 14,3/9,5mm
thanks
thanks Benny
for the cuts i use a tube cutter like this :
http://www.a-c-shop.de/Schlauchschneider
it´s the cheap version of a tube cutter but it works good for me
Send me a PM
merry xmas ferhan
Thank you fhantastic for answering my last lot of questions, I do appreciate it.
The only challenge with posting new photos in now I have more questions.
The sleeving in the first photo, is the blue sleeving a new colour that Nils is stocking?
As it looks more of a "electric" blue than Grand blue.
Also is that the gray sleeving next to it.
Sorry, I asked the same question in the cable sleeving guide as well, but I love that blue and really need to know.
Or is it just the light playing with my eyes.
