First off I would like to give my hats off to the original builder of this cascade.
NoL built this for me sevaeral years ago before I started building but it got banged up in transit by FedEx which resulted in a massive first stage leak and very slow leaks in the second and 3rd stages. Well this unit has collected dust long enough so now its getting an overhaul and will find its way to GunSlingers benching room.
Brrrrrrrrrrrrrrrrrrrrr......
Pict as it looks today
Unit is going to be cleaned up painted rewired and put onto a rollable benching cart.
Suction hose is getting replaced with a 5 footer
The familly of gases which will be used:
r14 (small 5lb tank)
r1150
and
r507 or r404 or r402a still deciding...
To do:
Add handvalve
Tune the charges of r14/r1150
Insulate
Paint base
Add digital temp displays
Rewire electrical using those corragated wire loops you see in the pictures including on off switches for the 3 stages and bypass
Add top of cart and mount suction line to cart with bracket to keep it stable at the connectors...
Misc touch ups to make it pretty...
![Send a message via AIM to [XC] gomeler](images/misc/im_aim.gif)
