Did not end up buying the mb waiting for socket h.
I currently own the Gigabyte 790FX UD5P pretty good overclocking board, does what i ask of it.
MSI 790FX GD-70
965 BE C3
4Gigs Corsair GTS 2000 Cas 8
Noctua U12P Push Pull
The 790XT-UD4P from Gigabyte has treated me well. For a mid range board it has unlocking features and overclocks well. Unlocked my 550BE to all 4 cores and will see it up to 3850MHz while it's still a dual core.
Other users also rate the GD70 from MSI but I have no personal experience with it.
I'd go with MSI myself, seems to be the best board around.
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
^ My friend has that board. He has had a 720be + 2x2 mushkin ddr3 ram [not sure which set] at a 25% overclock for the past 8 months.
Runs like a charm still.
heatware chew*
Video card....really can't beat the Radeon 5770 (anywhere from 160 CDN to 190 CDN). It has Direct X 11 support and is just as fast as a 4870 (+/- a few %'s in certain games).
Personally I like Gigabyte mobos for AMD builds. Haven't had a single one die yet...of course I'm not as hard on them as Chew is.
My best boards have been cheap ones Biostar T-Force usually work great and are great Ref clockers.
AthlonII 620 @ 3.6+ 1.5v+ / 8GB G.Skill 6400 / PNY 9800 GT EE 512 / Biostar TA790GX A2+ (HEPC) | 905e @ 3.2+ 1.35v / 2GB G.Skill 1333 MSi / 785GM-E65 (HTPC and AM3 testbed)| Kuma 7750BE @ 3.2+ 1.35-1.45v 6GB Kingston 667 Sapphire 3850 512 Biostar TA790GX (AM2\2+\3 testbed) | Gateway lappy Tl 52 2GB | Athlon XP @ 2.4 2GB Mushkin DDR 400 Shuttle AN25N Ultra Sapphire 2600Pro 512
All crunching and Folding from time to time
CPUs are like stock, PAST PERFORMANCE IS NO GUARANTEE OF FUTURE RETURNS-in other words, Expect No OC and be happy if you can OC!!!!!!!
Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
--- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
--- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
Deleted
Yep thats what it felt like.
The million dollar question is why was it weaker, and what actually blew up if it wasn't a mosfet.
Granted prime blend at 4240 is stressfull......but then again I tossed same chip in gigabyte and pulled off a 4250 prime blend.
I totally expect boards to die under ln2.......they just aren't built for that, air and water this should not be an issue, couple that with the fact that this is on a bench rig with multiple fans cooling everything......I would muster a guess that in a stifled case with not as much airflow that it would have died even sooner.
I still like the boards.......but unlike zalbard I will not lay claims that any board is better than the rest.
I will say XXX board is really good at this and that. That said if shooting for a nice mild OC, I really like the performance and layout of the msi. If pushing the extremes I would avoid it.
heatware chew*
I still like my second Crosshair III Formula, the first one i owned was just as good.
Nice and stable, good voltages and nice bios options.
Also like the tweak it function a lot!
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
heatware chew*
heatware chew*
I am excited to get my new waterloop up and a c3 to see what it can do. I hope the GD70 does me well because I purchased it with water in mind. My girlfriend and I are going to Europe to visit her family for a couple of weeks in December and I'm going to order the anfi-tech mosfet block for my board while I'm there and than hopefully get it all up and running when I return.
and then on to the giga and cold.
take a look at current DFI offerings as well. The DK 790FXB-M3H5 is very nice, if u want to go a bit cheaper, u can look at the JR 790gx-m3h5 or even the BI 785g-m35. All overclock and perform similar, just differ in size, features and therefore price...
1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
