Is there any guys in the DFW area that do CNC work or know of one that isn't an arm and a leg? I want to cut something out of the window panel of my Haf 932 for Project Slumber Parties.
I can help you out. PM me details and I will get you hooked up.
MV-G
3770K 5.00
7970 1200/1700
GSkill 2400
Seasonic Platinum 1000
Silverstone TJ08-E
- Koolance AC-370 - Swiftech MCP-35X - Phobya Xtreme 200mm Rad - Koolance VID-AR797 -
USA National Debt
Haven't heard back from Bei Fei so still looking. The problem is I can't find the font anywhere. It will have to be extracted from an image then imported somehow.
The character between Slumber and Parties is what I'm after
I traced it on a piece of notebook paper from a bag then traced it onto the panel. Just got through screwing up the panel trying to jigsaw it out. It ripped the metal loose at the raised part for where the side fan goes. What a cheap flaw in the case. So now I have to order a new panel from CM.
So if someone has access to a CNC or Waterjet and can help me out in the DFW area it would be greatly appreciated.
