Ok i still cant figure out why when i enable my onboard sound my system freezes as soon as i boot to windows. Im using remix 3.14j drivers and still no luck. WTF is going on???
I'm thinkin its those drivers your using. If your not using the official ones then you really shouldn't expect everything to work perfectly.
use the regular driver.
Dell Studio XPS16... no desktop![]()
yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
Uninstall the driver and reinstall it...or use a different driver. It's obvious that it's the driver that's causing the problem.
Sig goes here
If your your going to be switching drivers use these 2 programs before updateing your drivers Nforce Recet and Drive Cleaner links to both can be found from here http://mwarhead.motherboardfaqs.com/ make sure you fallow the instructions and to answer yes to install the SW ide drivers.
What it basicly does is, it installs the origanal Windows chipset drivers before you added your Nforce drivers and driver cleaner cleans out all the old reg files.
Woof!
Cooler Master 110 case w/window and cold cathode/Sony E540
I7 920@4.4Ghz 210x21 Megahalems
Gygabyte GA-X58A-UD3R
OCZ 6Gb DDR3 1600
XFX ATI 5770 960/1400
Seagate Barracuda 1.5tb
Lite-On DVD RW iHAS220-08/Sony Optiarc AD-7190S
PC Power & Cooling Silencer 750
That's my 2008 Street Glide.
cowpuppy...excellent!...thanks.![]()
I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
Hunter S. Thompson (1939 - 2005)
Yw Dude, Thats what I love about ES everyone can learn somthing from someone else even from a a middle wieght newb like me. I may be calling upon some of the greats like yourself in the future as I will be stepping int phase change in the next week or so after my Mach2 arives :-)
OCZ 6Gb DDR3 1600
