Just curious about user experiences with TEC's and
P4's...... I'm going to be watercooling soon and am
thinking of going peltier route.....
Well, I don't have too much experience with P4's and TEC's, but i can tell you that you wont need a super 200+ watt TEC with a P4. I believe that a P4 at 3.0 only puts out around 80w, so I would think you could cool one sufficiently with a 156w or 172w TEC quite well.
If you're not serious about being "hardcore," then a TEC maybe more trouble than its worth to you. I think you may find that H20 is sufficient in cooling your P4. For the pelt, you'll need an additional Bench Powersupply, and you'll definetly be voiding some warrenties when you cake your mainboard in silicone to protect it from condensation. Sometimes, it can be more trouble than its worth, thats all.
But, if you fall into the "hardcore" category, by all means, hook up a 172w pelt and give that P4 the chill!
A CPU Cycle is a Terrible Thing to Waste....
More like 101-113 wattsOriginally posted by Neptune5k
Lets say your using a 2.26, at default the cpu puts out 56.0 watts at 1.5v
Now to get to 3.0 you probably will need 1.75v, and that will dispell 101.18 watts
If your using 1.85 watts the vcore will be 113.07 watts
P4 3.2
P4C800-E
Xtreme Tek Werkz Typhoon waterblock
Maze4 GPU Waterblock
Mcx159-P w/10,500rpm counter-rotating 50mm JMC fan
Mushin BH-5 Promo build 2-2-2
9800 pro with silversink ramsinks
WD Raptors
My Heatware
nw 2.2b@3196, 1.88v, swiftech + tec 225w at 14.8v, full load -20 K
I've used a Danger Den Maze 2-2 w/two 172W pelts on my Soltek SL-75EVR with my XP 2100(Unlocked,Man was That a Pain!),but I have since then sold my system and went to an ABIT IT7/P4 System(Waiting for The Flame,Go Ahead!).
I've put the Maze2-2 on my P4 system with an adapter from Danger Den and am running only chilled water(16c).
Just Wanted to ask What do you think about putting the two 172W pelts on my IT7/P4 System.
Overkill?
4930K@5.2GHz/ASUS RIV BE/G-Skill 16GB/4x EVGA GTX 780Ti Classified Kingpin Edition with EK-WB's/4x Rosewill Hercules 1600W PSU's for GPU's/Thermaltake 1200W for MB/Cooling: CPU-Vapo, MB/GPU: A/C Conversion Chiller
The 156w on a 15A@12v PSU was not enough to support my P4 @ 3.5Ghz
I could reach very cold temps but the maze3-1 block maintain those temps under full load.
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
