Page 92 of 92 FirstFirst ... 428289909192
Results 2,276 to 2,300 of 2300
Thread: Intel 4.5GHz & 5GHz LinX Stable Club
  1. #2276
    Jun 2010
    Germany
    3570K 4.5Ghz
    Click image for larger version.
Name:	Linx 4.5Ghz 1.152 Vcore.jpg
  2. #2277
    Feb 2008
    NYC
    Quote Originally Posted by dr_dx View Post
    Do you know what post that is? I didn't see it on Zalbard's original post. If in fact that was decided, it would be good to indicate that in post #1 so people will know what the "current" requirements are (like using AVX, etc.). Running "MAX" RAM is not a good solution. I know I have 16g of ram but have been testing at 7168 simply because I didn't want to sit around for 3 + hours (much less 12 hours like the above poster) to complete 20 passes and that is a very common amount for folks running 8G RAM to test with. Historically, most of the "accepted" runs are between 60~90 minutes. IMHO, since RAM amounts vary greatly, a better solution would be to set a minimum time that LINX has to run without an error. That way guys that run a lot of RAM aren't penalized by having to run for 12 hours and conversely you don't have these 13 minute runs of less than 2G RAM either. Somewhere between 60~120 minutes should be sufficient to verify system stability.
    9216 was decided on because it is(was?) the maximum memory that LinX can address before suffering GFlop dropoff when HT is enabled.
    It is always best to use the most ram possible. If you do not, you are not testing stability. I have seen on a number of occasions myself where an OC I have will pass with 5120MB, but when set to 9216 will fail.
    Above 9216MB stress drops drastically.
    Core i7 990x @ 4665MHz 30x155.5 | ASUS Rampage 3 Extreme 1601 Modded BIOS | 24GB (6x4GB) Mushkin Redline 999057 @ 1866MHz 8-8-8-24-1T
    2x MSI N770-2GD5/OC SLI Custom BIOS @ 1228/7464 | Samsung 840 EVO 1TB | 4x 3TB WD Red Raid 5 | Corsair RM1000 | 2x Dell SP2309W 2048x1152
    H2O Cooled | EK - Supreme HF Full Gold - FB RE3 | Swiftech - MCP35x2 - MCRes Micro v2 | HWLabs - 2x GTX 120 - GT Stealth 120
    7x Gentle Typhoon AP-0A 2150RPM | 1x Enermax Magma UC-MA12 1500RPM | Lian Li PC-A10B | 5GHz Gulftown
  3. #2278
    Jan 2003
    Norway
    If LinX was the ultimate stability test proving an absolute stability in a system I would be more inclined ta agree with a "All memory" or as much as possible requirement. But, we all know that neither LinX nor Prime testing provides any such guaranty.
    Therefor LinX testing with a time limit and reasonable amount of memory makes just as much sense to me
  4. #2279
    Jun 2010
    Then, with such a debate now raging, how is one to know just what actually will constitute a valid qualifying run?
    Also, without trying to fuel the conflagration further, is CPU-Z a requirement? It doesn't seem to get valid readings with this particular i7-3820/DX79SI combo. The Vcc, for example, seems permanently locked at 1.000 Volts and the RAM/SPD tabs are totally off the wall. I tend to stick with Intel's own Tuning Utility to get proper read-outs...
  5. #2280
    Feb 2008
    NYC
    LinX is superior to any other stress program out there. That does make it 'the ultimate' stability test.
    I have yet to find an overclock that will pass a 9216MB LinX that won't run 24/7/365, unless there's a stability issue in one of my GPU's. Which of course has nothing to do with my CPU overclock.
    The majority of people who claim LinX isn't good are just flat out doing it wrong. They're either using outdated binaries, or not all memory/diagnostic mode.
    CPUZ is a requirement.
    How you're supposed to know what a valid result is? read the thread.
  6. #2281
    Jun 2010
    Quote Originally Posted by zoson View Post
    I have read the OP, which is where the "rules" have been initially stated. However, I have NOT read all 92 pages to see how many times things have changed since the author left.
    And I'll certainly be glad to use CPU-Z, since it will make my system look sooo much better and have everyone wonder just how I managed such a feat on battery power and the world's slowest RAM:
    But that may be after I remove all of my Quad-channel RAM for Dual, since it's only 4 GB and I won't have to be hobbled by incredibly long qualifying times.
    And thanks very much for crediting me with nothing but frivolous questions. I believe I'll pass on this offer...
  7. #2282
    Dec 2008
    MALAYSIA
    Just to show that LinX 0.64 is not as stressful as prime95 27.7 in terms of vCore...
    3770K @ 5.0GHz
    LinX for 1 hour @ 1.416v... passed
    LinX for 7 hours @ 1.448v... 1.416v-1.434v BSOD
    straight away run Prime95 at 1.448v... failed in 1 hour +
    bump up to 1.48v... passed 4 hours + prime95
    SUCCESSFUL TRADE LIST RM600k+
    ^^ Malaysia's Overclocking Enthusiast Community Website ^^
    Find us at Facebook HERE
    XS Successful Trades:
    G.Skill RipjawsZ 2400C9 4X4GB - sold to easegantini | G.Skill RipjawsX 2133C8 2X2GB - bought from Dumo | 2600K 57X - bought from newhit | 3770K 6750 - bought from Viss | 3770K 6750 - sold to Sniper | 3770K IMC 2800+ - bought from Dumo | G.Skill Pi 2200C7 - bought from websmile | 3770K IMC 2933+ - bought from Viss | DomGT 2kC7 3X2GB - sold to _AntLionBR_ | G.Skill Pi 2133C8 - bought from websmile | DomP 2800C11 - bought from Alex-Ro | Pi 2000C7 - bought from websmile | GTX4 + KVR 1333C9 - bought from TaPaKaH
  8. #2283
    Jun 2010
    I also kinda wonder where this magic figure of 9216 MB comes from, since there doesn't seem to be a way to set it in my copy of LinX. There is not a direct mem setting, nor does choosing any available problem size set it. I would second having to point that "requirement" out in the thread as well rather than just claim no one knows how to properly use LinX in the first place.
    Again - since the author has left and there is no real control here, and no two people seem to quite agree on anything...
    ...what's the use?...
    EDIT -
    BTW, LinX's most useful feature is it's ability to run multiple instances (face it - it's just an interface to Intel's LinPack, a feature shared by myriad stress tests outside of Prime95) as well as setting the thread count and problem size. Here's an example of how I find it handy when testing a rig's stability, where I've tried to push not only the CPU freq but to push out the Turbo capabilities as well:
    The rig's set for ops at 1.25x BCLK, and on the CPU I use 32x (4.000 GHz) for boot with the four available Turbo slots set for 37-40x (4.625-5.000 GHz)
    Test 1 - Single-Core speed of 5.000 GHz using a small problem size to maintain speed on the CPU. (It's hard to "lock in" the true single-thread speed with the OS in the background, so I grabbed a shot with sensor lag spread between the two monitors showing both speeds as it shifted. The graph line shows it sticking to that range during the run.)
    https://skydrive.live.com/redir?resi...021B73932!1091
    Test 2 - Locking in the 2-Core stepping at 39x. A larger problem size for more use of RAM, but not so much that it kicks in hard enough to drive the system core count higher than needed)
    https://skydrive.live.com/redir?resi...021B73932!1093
    Test 3 - 3-Core speeds, and a little more headroom for RAM use without kicking in that fourth core.
    https://skydrive.live.com/redir?resi...021B73932!1092
    Test 4 - things get a bit more interesting here. A full eight threads, but with three instances of LinX doing the same while running simultaneously. Emphasises multi-tasking as well as multi-threading in one shot.
    https://skydrive.live.com/redir?resi...021B73932!1094
    But I could do all of the same things with Intel Burn Test. Or even OCCT - and get all of the features of LinPack as well as incredible logging features.
    LinPack is LinPack, that's all...
  9. #2284
    Feb 2008
    NYC
    You can set it in the Memory(MiB) textbox... Just unclick the 'all' button and type it in.
    9216MB, as I explained before, is the maximum memory linpack can address while HT is enabled and maintain full performance... At least that's how it is on Gulftown and lower. I haven't had time to test my 3930k yet.
    Also, owikh84... You're obviously not using updated linpack binaries, AND you're not using as much memory in the LinX test as your Prime95 test. So yeah, apples and oranges comparison from someone who doesn't know how to operate LinX doesn't prove anything other than your lack of skill.
  10. #2285
    Jun 2010
    Then consider this post a placeholder until I can generate a run in the morning. I'll edit it in so as not to add another to this already lengthy conversation...
  11. #2286
    Feb 2008
    NYC
    Quote Originally Posted by owikh84 View Post
    lol i played with LinX more than you dude.
    I'm using the latest LinX 10.3.11.019 & Prime95 27.7 build2
    Mem stressed on LinX was even more than what was set for Prime95 of 7000MB
    Other than that pls try it yourself before even posting here.
    We can see your memory usage in your prime95 screenshots and in both it's greater than your memory assignment in linx... So yeah, nice try. Also, all of the older members of this forum will laugh you off the forums for thinking you've done anything 'more' or 'better' than I have.
    And if you are using the latest binaries, your overclock obviously has something wrong with it seeing as in the last two pages everyone at 5GHz is 2-4GFlops higher than your performance.
    Lie more noob.
    Lastly, if there were ANY truth to what you were saying, Intel would stop making LINPACK and just test with Prime95 instead. But oh yeah... They do make LINPACK, and do their own stress testing with it.
  12. #2287
    Sep 2002
    in front of PC
    lol most prolly you didn't do much observation bro..
    mem selected for stress IS NOT the green bar you saw in task manager, ......
    Just asking.......
    Is the LinX memory over 7Gb and the Prime memory 6Gb?
    Thanx
  13. #2288
    Dec 2008
    MALAYSIA
    Quote Originally Posted by newhit View Post
    Just asking.......
    Thanx
    LinX >7GB, Prime95 7GB
  14. #2289
    May 2009
    Dr_Dx | Core i7 3770K [4C/8T] @ 5300.3MHz | 1.488v | ASUS Maximus V Formula| Water | L221B009 | LinX 0.6.4 AVX w/ Linpack 10.3.11.019 | Liquid Pro 7168 RAM
Name:	5.3Ghz_1.488v_126Gflops_LinX_0.6.4_AVX_Linpak_10.3.11.019_ultrpro & temp 1280.jpg
    Dr_Dx | Core i7 3770K [4C/8T] @ 5300.3MHz | 1.488v | ASUS Maximus V Formula| Water | L221B009 | LinX 0.6.4 AVX w/ Linpack 10.3.11.019 | Liquid Pro 9216 RAM
Name:	5.3Ghz_1.488v_126Gflops_9216_LinX_0.6.4_AVX_Linpak_10.3.11.019_ultrpro & temp 1280.jpg
    All else identical except tested RAM amount - GFlops are lower with 9216 RAM...Looks like 9216 is not the "best" amount for an IB...
    I7 3770K @ 5Ghz @ 1.288v 24/7 Liquid Pro
    Asus MVF 804
    EK Supremacy Plexi plate#3
    factory chipset waterblock
    custom water
    2x8GB G.Skill TridentX 2400c10
    Sapphire 7970 Toxic
    2x120GB Raid0 Sandisk Extreme SSD sata3
    3x2TB Seagate Barracuda XT sata3
    Antec HCP 1200
    Antec 1200
    Win7 x64 Ultra
  15. #2290
    Feb 2008
    NYC
    That's within margin of error from boot to boot. 125.79 vs 126.46... Less than 1 GFlop.
  16. #2291
    May 2009
    Dr_Dx | Core i7 3770K [4C/8T] @ 5000.1MHz | 1.288v | ASUS Maximus V Formula| Water | L221B009 | LinX 0.6.4 AVX w/ Linpack 10.3.11.019 | Liquid Pro
    Same Boot @ 5Ghz in order of GFlop performance
Name:	5Ghz_1.288v_LinX_0.6.4_AVX_Linpak_10.3.11.019_ultrpro mem comp6 1280.jpg
    9216 is way down the list (there were actually 2 other mem settings that were faster - didn't have the room to show), but it's clear 9216 is not the setting to give max GFlops.
    Zoson - You have yet to show us the post # of where Zalbard or the "community" decided on 9216 for the RAM setting. Several people have provided accurate measurements; all you have provided is hearsay.
    It's time to put up or shut up. Otherwise folks will think you are just a TROLL.
    Asus MVF 804
    custom water
    Sapphire 7970 Toxic
    Antec HCP 1200
    Antec 1200
    Win7 x64 Ultra
  17. #2292
    Jun 2010
    While I'm still tryin' to get more than 20 minutes' stable here (a bit trickier than I imagined based on how well the rig runs with a 5 GHz top Turbo), I have to admit to being stumped on everyone's incredible through-put rates. I seem to enjoy but an embarassing 50% of that, and I had thought this system to be designed for such. Apparently not so successful at it, either.
    I would be most appreciative if anyone would be willing to point out some specific posts or threads on this. You need not walk me through a hand-holding session - just point out where I can do some relevant research, if you would...
  18. #2293
    Feb 2008
    NYC
    Do a thread search for 9216 you lazy bastard.
    You're the one who's late to the party, not me. You have to do your research and homework.
    It also looks like the reason why we chose 9216 may have been fixed. There are TONS of results showing the issue in this thread.
  19. #2294
    May 2009
    Lazy Bastard? Lying Noob? That's the pot calling the kettle black. Your search button broken? There are 15 posts in this thread (most of them recent) that have "9216" in them and none of them show where Zalbard or the "community" decided on 9216. You started a discussion in 2011 about it but no one agreed to it. Zalbard updated the OP in 4/2012; If 9216 had been decided upon, he would have put it in. And now you are giving people a hassle over something that isn't even an issue anymore but you were too lazy to verify was still valid.
    I am sorry that you can't get your 3930K onto the list but that is no reason to take out your frustration on everyone else that is trying to comply with the requirements set out in the OP. Try being helpful, instead of critical and calling people names. It's because of TROLLS like you that this thread is dying.
    Asus MVF 804
    custom water
    Sapphire 7970 Toxic
    Antec HCP 1200
    Antec 1200
    Win7 x64 Ultra
  20. #2295
    Oct 2008
    Lake Bodom
    I agree on this, after I got my 3960X I saw it much harder to stabilize P95 than LinX. Well of course LinX GFlops may tell if something is really wrong, but usually I got a BSOD in P95 right after one hour or so even if LinX passed with flying colors. My 990X on the other hand was a different story, LinX was more stressfull.
    On my 990X, after I upgraded from 6 to 12 GB, the max mem I could use with LinX was that 9216MB, otherwise I would get a radical drop in GFlops.
    Core i7 Extreme 4960X @ 4.5 GHz, Asus Rampage IV Black Edition, 32 GB Corsair Dominator GT DDR3-1866 MHz, GTX 780 3-way SLI, Corsair AX1200, Corsair 700D, Corsair H100i, Corsair Force GT 180GB, Windows 8 Pro, Asus VG278HR
    Core i7 Extreme 990X @ 4.4 GHz, Asus Rampage III Black Edition, 12 GB Corsair Dominator GT DDR3-1866 MHz, EVGA GTX 580 "Black Ops" SLI, Corsair AX1200, Corsair 650D, Corsar H100, Samsung 830 256GB, Asus ROG Thunderbolt, Windows 7 Pro
  21. #2296
    Feb 2008
    NYC
    At no time did I say zalbard decided. just the community. And it's in there if you read the discussion. Cryptik, donmarkoni, newhit, xarot, and several of the big players in this club all agreed based on the results from our testing. This was all started by people noticing that there was a sharp GFlop dropoff between the 8192MB and 10240MB settings.
    lol, my 3930k isn't in the club because I didn't bother trying. It's an HTPC and I don't need it running that fast. It's got an air cooler on it... Way to attempt an insult and fail miserably.
    Also, way to not address the fact that the whole reason why we decided on 9216 may be fixed now.
    LOL@U. Keep trying, but you're just a failure.
  22. #2297
    Aug 2009
    Sofia, Bulgaria
    Thumbs up Updated Linpack libraries
    Bumping the threat with Limpak updated libraries ver.11.0.1.005
    You need to copy also the libiomp5md.dll file from redist directory for 32 or 64 Win u use in Linx folder.
    PROUD|REX|E8600|2*1GB HYPER|9800GTX+ DK|on AIR
    XOCT |RIIIBE|i7 920|3*2GB HYPER|4890 MATRIX|460W Enermax 3in1 24p|SyncMaster 940BF|on AIR
    MEMBER|RIVBE|i7 4960X|4*2GB HYPER|GTX 470 SOC|1KW SilentPro|TV|Seidon 240|
  23. #2298
    Aug 2018
    ASUS P6X58-E WS, Water Cooled, i7-980X, 3045A974, 4.81GHz, 1.536V, 101.8569 GFlops
Name:	4.81 GHz...jpg
  24. #2299
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    Quote Originally Posted by big.al.v View Post
    Very nice values. Just water?
    When i'm being paid i always do my job through.
  25. #2300
    Oct 2007
    Chicago,Illinois
    Thumbs up Let me in
    ha ha ha ha
    I7-8086K
Tags for this Thread
