Well, here is an odd name for something i've had in my mind for over 4 years. I finally decided to purchase the case of my dreams, the widely known and more-than-seen-and-modified Silverstone TJ07. This is not going to be just another TJ07 build, this will be my last case (hardware will be upgraded occasionally) so i'm going to make it special, hence the project name.
It's going to be all black inside, there will be acrylic panels fully customized for the needs of this build and already in production, and will feature a dual loop, one for CPU and Motherboard, the other being used for the graphics card. Enough talk, here's the hardware, most of it is from my older build. The current case will house my GF's PC in the future...
Computer parts:
- ASUS Rampage II Extreme motherboard
- GSKILL Trident PC3-16000 6GB RAM
- Intel Core i7 920 CPU
- EVGA GTX295 video card (might change soon, undecided)
- PCPower & Cooling 750W Power Supply
- Intel X-25M SSD x2 (RAID0) for OS
- Samsung HD103SJ 1TB x2 (RAID0) for games, data, etc
- Alphacool LCD dual bay
- Scythe KAZE Master fan controller
Watercooling parts:
- Two Swiftech MCP-350 pumps
- EK Acetal top for the pumps
- EK 150mm reservoirs
- Watercool HeatKiller LT CPU waterblock
- Feser 480 Radiator
- Feser 240 Radiator
- Black Ice GTS 240 Radiator (for the top, might not use it)
- Fractal white fans (undecided, depends on looks)
- Enzotech 3/8" ID 5/8" OD fittings
- Bitspower full cover block for Rampage 2 Extreme
- EK MOSFET waterblocks in acetal
- EK Nickel and plexi full cover block for the video card (undecided on video card)
- Feser tube, colour depending on theme but will probably be white/blue (undecided)
- Aquaero, will use it if i find a place to put it where only the display can be seen (undecided)
Well, this is about it. I already bought some items and i currently await the fabrication of the acrylic parts so i can check proper clearance for every other component and what goes where.
First thing to get is obviously the case...
Here, starting to unpack and check whether everything is okay inside:
Yeah, poor neighbors... I play guitar and it's not soft music at all
Oh, there you are Doesn't look bad, let's proceed
Out of the box, everything seems to be in place. This is the older version, but it doesn't really matter as the tray will be *heavily* modified. I said modified, not butchered, no worries there
Some of the guys that will make part of this project, first ones to arrive
I really love this pump, loads of pressure and no noise operating.
Schythe Kaze Master, my preferred fan controller, will help me control noise/performance if required. Also it will cut down the dull look of the front case panels.
Swiftechs...
One of them has to be returned, it's missing some sort of holder in the bottom
Unpacking the Kaze Master is a delight. Carefully packed, looks like it's got real high quality, and i surely hope so.
Components...
Blurryness
Still with the protective film applied. Looks great tho
Last but not least, the great EK reservoir, let's see which colour will you hold inside
I love these brackets. Eddie surely knows his thing, looks great.
That's it for now, currently waiting for the radiators, more blocks and most importantly the acrylic parts which will allow me to proceed butch... er... modifying the TJ07
Yes, there's an SLR being planned in the future as well as some photo lessons
Enjoy!
