Hi,
Wondering what the fsb holes for the Classified are? I've been trying to reach 4.0ghz on a 920 D0 and had some difficulty after 190 bclk. So I was curious what my highest bclk for my board and lowered multiplier to 12 to take cpu out of equation and also reduced memory multiplier to 2:6 belowed 1600 spec (which works at 160x10). Then in E-leet slowly upped the clock frequency 5 mhz at a time. Eventually I got a BSOD around 187 (Error 3B) right after hitting the apply button in E-leet. I even tried raising the qpi pll and other voltages in eleet a couple notches and still got the BSOD. I also turned off vdoop, set cpu vtt +200, impedence to less and middle, cpu + vtt freqencies to 490/900. I'll fill out a proper template in a bit but my main question is does the Classified have fsb holes?
Thanks.
