Is there a way to find the cause of my Phenom II 550BE not being able to go above 3.9Ghz? Basically I get a stable overclock till 3.9Ghz, but as soon as I try to go for 4.0Ghz the system will simply boot loop. It'd reach the Windows screen where the little bar moves around and then restart without any evident cause of the failed boot.
I have no problem with the 3.9Ghz so all I want is to know what is causing it. Like, is it the CPU (bad chip...one of the unlucky ones), mobo...not enough ram...or if it's me not doin' it right lol.
Now, I've been at it for quite a while and I've tried many different "tactics" but they all end up with the same boot loop so I don't wanna waste my time any more with a lost cause...I just want to know why so that I can learn from my mistake and maybe watch what I buy/do next time. Learning is basically what I wanna get out of this, as I am new to overclocking. I don't take any classes on IT nor do I go to college where I can learn it or anything so everything is self taught on my own time.
I had to reset cmos because of my last experiment that I did and failed so I thought I'd start again (as if I won't end up at my 3.9Ghz as before but it's no big deal) meaning I can't supply you with screenshots for now on things you might need to help me with this, although I could tell you how things were while I had my stable 3.9Ghz oc. Though this is not as much about the oc as I said, but what is the causing it to not be able to be realized.
Thx in advance to everyone who'd take the time to help me understand the situation a little better.
