You guys can check out my C3 965 review here
http://www.techreaction.net/forums/s...ead.php?t=1204
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
Thanks for all the time you put in, nice review.
I'm pretty comfortable saying that C3 is a 4Ghz 24/7 chip.
Asus G73- i7-740QM, Mobility 5870, 6Gb DDR3-1333, OCZ Vertex II 90Gb
Excellent and very complete review........about 4.35ghz for watercooling
AMD 1090T@4.0ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus Crosshair IV Formula
ht 2400mhz / nb 2400mhz
12gb Gskill 1300mhz
HIS HD5970
Enermax Evo Galaxy 1250
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
Phenom 2 125w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=117414
Phenom 2 140w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=109214
Phenom 2 AM2+ 940 cold air results
http://futuremark.yougamers.com/foru...ad.php?t=97430
If I dont get every single drop out of my cpu I feel like someone is stealing from me
so were/when can we get the new C3 chips ?
What is the batch, stepping (ex: CACYC), and last 4 digits of your chip's serial number?
I was really hoping for more: you're better at this overclocking thing than I am, and you're using an AMD supplied review sample as opposed to a chip I bought retail, but your results are almost the same as what I'm getting from a C2.
(Pics or it didn't happen, right?)
4h prime stable is different than 30 minutes I know, but with these C3's having an NDA and all I really expected to be floored. At least I won't have to spend any money on one just yet, that's a plus.
Intel i7 3930K C2 4.6GHz 1.33V
MSI Big Bang - XPower II
Noctua NH-D14
G.Skill Ripjaws Z 4x4GB 2133MHz
Sapphire HD 7970
Mushkin Chronos 120GB, 2X Seagate 1TB
Corsair AX 1200W
Cooler Master HAF 932 Advanced
Yup
you talking
4.1ghz prime on air.........cant do this on mine with water
4.2+ghz prime on water (cant do that either but mine will bench at 4.2ghz 32bit and 4.1ghz 64bit)
4.35ghz bench stable water (cant do that at all only screen shots)
4.49 superpi 1m I can do 4.41ghz
I see only 150mhz-200mhz difference than what Im doingIts good but not $200 good for where Im at.
Unless something drastic happens to my cpu or I come into some extra money I may pass and put the money towards a 5870x2.
AMD 1090T@4.0ghz
12gb Gskill 1300mhz
HIS HD5970
4.61ghz water
Thanks for review chew*
It's time to retire excellent 940BE and move on.
Board would need to go as well, I never ever before kept board for over 2 years in my primary rig!
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
Awesome review man. 15K CPU score on water that's awesome. Looks like I may need to put my 965 up for sale.
Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
--- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
--- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
great review chew and excellent results! thanks for covering a lot of cooling options. c3 really showed a well balanced improvement over the c2's and really promising for amd in the future. it really gets me excited to get a c3 myself.
btw, what did you mean about extreme watercooling? did you had any special cooling like an ac on a rad?
Phenom Monsta - Gallery
AMD Phenom II X6 1055T | MSI 790FX-GD70 | Dominator 1600 C8 8GB | 4770 CF | 2xWD640GB Raid0 | 2xWD1.5TB Raid1 | Corsair HX850 |Lian-Li PC-7FW
Enzotech Luna Rev.A | 2 x MCW60 | MCP-350 | XSPC Dual DDC Res | TFC Monsta 420/360 Limited Edition
Canon EOS 7D | EF-S 17-55 F2.8 IS | Nissin Di866 | D-Lite4 | 17" MiniSoft | 53" Midi-Octa | 7" Reflector + 20º Grid | Explorer XT SE | Crumpler 6MDH
Wow nice review Chew... I'll wait for the X3 Stepping C3...
Phenom II 720 BE X4 3.217Ghz @1.325v | NB 2.280Ghz @1.25v | HTLink 2.054Ghz
Patriot 10-10-11-30-42 1520Mhz 1.76v
MSI 770-C45 Bios ver 1.4
Sapphire ATI Radeon 4670 <-- still saving for 4890 T_T
Silverstone 500w
Artic Cooling Alpine AMD Pro <-- not good cooling T_T but affordable for me
As always, nice review.. I am pleased with the results. I look forward in adding one of these to my collection.
~1~
AMD Ryzen 9 3900X
GigaByte X570 AORUS LITE
Trident-Z 3200 CL14 16GB
AMD Radeon VII
~2~
AMD Ryzen ThreadRipper 2950x
Asus Prime X399-A
GSkill Flare-X 3200mhz, CAS14, 64GB
AMD RX 5700 XT
In that first IMC shot with 6-7-6-18 1T @1880Mhz and vCore 1.36V, was the NB also at stock volts?
Nice work on this review Chew, I can see you put in a lot of hard work here and it shows with the quality of your review
Looks like we have a very nice chip here, can't wait to bench one of these
Very good review, you guys must have a lot of time invested in this. Thanks for sharing the results.
Based on these C3 tests (air, water), I’d say I may gain 100MHz+/- over my 965-C2 but as always you never know until you test.
Nice work Chew and crew... really nice effort and very thorough. Stuff like that right there inspires confidence in the results! So, everyone else is saying it - would you feel comfortable saying that on water that most C3s are going to hit the big 4?
Daily Desktop Custom Built - Modified Data General Server Case
Asus M4A79T Deluxe | 955BE C2 Rev | 4GB OCZ DDR 2000 @ 1600 6 5 6 1T | 4850x2 + 4850 w/MCW60 | CPU on H20 w/ Enzo Sapphire l Custom Built Pump and Res Combo 1/2 Gallon! | 4 Swiftech 320mm Rads with 6 All Aluminum Delta Fans with their own PSU - Finger Loppers - for real!
Literally, CPU&GPUs are almost always at ambient therefore heat ain't limiting sh|t.
Yah water should be cake.....
When I say extreme water cooling I compare it to todays bling water setups..... that look cool but don't actually run cool.
Not .01 degree is sacrificed for looks, loop is closed cpu only with a t-line fill port......no res etc etc pump runs off dedicated PSU with 12v rail sens modded to 14.4........basically its old school.
heatware chew*
TBH I used the worst chip I have here for the review just to keep things in perspective so as to avoid certain discrepancies that may have happened when i reviewed 955.
1/2 prime well you already said it......I run over 3 hours for a reason, usually if it gets past 3 hours you are good to go.......why becasue after 3 hours it repeats the same loop of tests
Also read my sig
heatware chew*
That's good to know you're working with a bad (comparatively) one that clocks nicely. I have some C2's that need 1.53V to run 3.5....
Good 965's should be GOOD then, and that one is probably representative of the X2's and X3's that will hit retail. Awesome.
Wow love the high clocks with lower voltage on Air. And your memory timings + NB clocks are insane.
heatware chew*
Nice review, when is the C3 Coming out ?
MSI 790FX GD-70
965 BE C3
4Gigs Corsair GTS 2000 Cas 8
Noctua U12P Push Pull
heatware chew*
thanks, i thought there was some special cooling you did when you said extreme so that would mean a typical water setup then, that's really good to know.
i prefer simplicity and functionality with better looks (i don't consider mine with much bling though) for my rig since i use it 24/7 but it also cools my chips too the way i wanted it to
