We did an HTPC build back in 2007 that was a lot of fun. We've revisited the subject and used some great new products including our H50 CPU cooler, X64SSD, CX400 PSU, and 2 different memory kits.
Take a look here:2009 HTPC Build Log
Yes, Yellowbeard, a tall rough man with a big yellow beard
Very nice
Very cool. Kind of angry I didnt get that mounting hardware with my H50 though......
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
Do you need better or different mounting hardware?
https://shop.corsair.com/store/default.aspx
Not so much need better but the 775 sticks on to the back of my board like most and I am planning on going to 1156 soon so just saw how that new plate mounted and seems to be a lot better than having to take off the 775 plate. Will check out that link thanks.
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
Even with the new plate, you'd have to remove it to go from 775 to 1156. You have to change the location of the threaded inserts to fit the hole pattern.
NEW H50 BACKPLATE INSTALLATION GUIDE
Awesome just ordered the new bracket. Very nice that is it free just had to pay a 5 dollar shipping fee.
Thanks for the link Yellowbeard
Yes but I have no 1156 bracket unless I would go with eVGA board which has 775 holes.
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
