Has anyone powdercoated the outside of their aluminum case? Is this a bad idea?
I'm also looking at automotive paint the 3 jobs that do 2-3 layers. Anyone have experience?
I powder coated the exterior of flow, it can be risky because powdercoat is especially susceptible to orange peel and this cannot be sanded out. - you need a very very good coater to get a flat finish if it is possible at all. I would try to go with an automotive paint if this is available to you in the color you want
I've powdercoated the exterior on 3 different aluminum cases. Twice were anthracite and one metallic bronze. All were very high gloss and turned out amazing. It was always the interiors that my powdercoaters had issues with.
I recently discovered this is not true. it can be sanded and polished just like paint. I was sceptical when I first heard of it as I have have dealt with powdercoated parts at work for the last ten yrs. and none of the powdercoaters we use had ever heard of it. but we gave it a try and it works beautifully.
EDIT: BTW harbor freight has a powdercoating gun on sale for $60 till 11/9 cheapest I've ever seen one
Help Save Lives Join World Community Grid!
Rampage Formula | E8600 | 2x2Gb Gskil F2-9600CL5D-4GBPI| Saphire 5870|2x intel x25-v 40gb, WD 640gb black| Silencer 750 | 655 > pa 120.3 > fuzion v.2 > ek nb5 > ek 250 | cm 690
Thanks for the share!
ive powdercoated 4 cases and alos powdercoat at my job: automotive and industrial parts
basically if you use the right powder and the right gun its comes out beautiful. ( http://www.tiger-coatings.us/ this is the best powder in the business)
the only problem is the inside of computercases, since the powder is applied with a static charge, hardrive and drivebays cause a "faraday" effect and its hard to make the powder stick in certain areas.
so u basically have to drill out the rivets to powdercoat and separate the pieces.
which isnt to hard and then u can replace them with nice screws which adds the the flare ;-)
good luck and if u have any more questions let me know
FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
Asus Crosshair Formula 5 Am3+ bios v1703
G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
MSI 7950 TwinFrozr *1100/1500* Cat.14.9
OCZ ZX 850w psu
Lian-Li Lancool K62
Samsung 830 128g
2 x 1TB Samsung SpinpointF3, 2T Samsung
Win7 Home 64bit
My Rig
Thanks for all the tips guys!
