+2 on that Bobby.
Dropping HT and going single channel will open up a bit of thermal headroom instantly.
GB 790XTA UD4
GSkill Pi Black 2000 Cas9
ASUS 4870
Enermax Revolution 1050+
http://www.heatware.com/eval.php?id=67661
wow, on air? And -15C in your room? haha, must be a cold winter :P What are the temps on that thing?
Nice job! HT is off, everything else is on, correct? What voltage did you need for that? B batch or A batch?
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
nice 1!
e8500 c0 - 4275MHz - 1,344 vCore
DFI UT P45-T2RS
4x1gb D9GMH
Ati HD4870
Modded HAF 932
Watercooled:
Heatkiller v3.0 cu - D-tek Fuzion GFX 2 - PA120.1 - PA120.2 - PA120.4
Did that on stock cooler myselfNice score, keep pushing
Thank you for the feedback folks !
Details:
CPU Batch Number: 3849B203
QPI Link: 1.32V
CPU V: 1.448V
MEM: 1.72V
PCIx: 125
Mem timing: 7-7-7-19-1T
vtt PWM Frequency: 610KHz
CPU PWM Frequency: 1333MHz
CPU Impedence: Less
QPI Signal Compensation: Less
*everything* else is on auto.
Classified just rocks!
I have taken into account your input and will remove two mem sticks on my next OC tests.
rouvio.
That's hot. Nice work!
"There's only 2 jobs in the Army, infantry...and those who support the infantry"
Intel 2600k @ 4ghz
Asus P8P67 Deluxe
16GB GSKill 1600mhz
MSI GF 560Ti 2GB
2x OCZ Vertex 3
2x WD Black 640GB RAID0
Windows 7 Professional x64
Great omg O_o
Game Rig:
Intel Core i7 920 (3.0Ghz) || EVGA X58 Classified (E760)|| 3x2 Gb A-DATA 1333Mhz Triple Channel + 3x2 Gb Patriot 1333Mhz Triple Channel || WD500GB + WD750GB + Hitachi 1TB || PowerColor Ati Radeon 5850 1024MB GDDR5 CrossFireX|| Chieftec 1020W || Acer 24" P243 (1920 x 1200) || Razer Copperhead Blue || Microsoft Reclusa || SteelSeries Seberia 7.1 || CoolerMaster CosmoS
Water cooling:
WC HeatKiller 3.0 || 2x 120mm Koolance || Koolance RP-980BK || Koolance nozzles
Wow Rouvio.
Can you mention what thermal compound or grease you use for that? Noctua's or something else 3rd party?
Nice clocks but that looks like a pretty old version of CPU-Z.....
What are your temps on that crazy clock speed?
Sure!
I have always used Arctic Silver 5. *always*.
Once you use it.. you can never go to anything else
That's the eLeet (EVGA's version of CPU-Z) version 1.06.3
Temps (idle of course..) for this clock are 45-50C.
Out of curiosity I did try to run SPi1M but never made it past the 5th/6th loop..
Well,
under similar conditions (but lower clocks & Voltage) I run SPi1M:
I know and have a "gut feeling" the system can do better. maybe even go close to 8.0s
The 4.75GHz is for records (personal), with no intentions of benchmarking.
In the following days I'll try to go higher and will update here.
*edit
nope sir! HT is ON![]()
whau. 4.713GHz superpi and AIR, have u a photo your PC system?
AMD FX-8350@5 GHz 1.52V + H100 Corsair, Crosshair V Formula-Z, 2x 4GB GSKill TridentX 2400 MHz+ 10-12-12-25, EAH HD6870 DirectCU, Corsair TX850W
CPUs:next 2x AMD FX-8350, AMD FX-8320, AMD FX-6300, AMD FX-4300, AMD FX-8150, AMD X2 555 BE, AMD x4 965 BE C2 and C3, AMD X4 970 BE, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD X6 1100T BE, AMD FX 8120 95W, AMD FX 8120 125W, next AMD FX-8150, AMD A10-6800K, 2x AMD A10-5800, AMD A10-5600K, AMD A8-3850, AMD A8-3870K, 2x AMD A64 3000+, AMD 64+ X2 4600+ EE, Intel i7-980X, Intel i7-2600K, 2x Intel i7-3770K, Intel i7-3930KAMD Cinebench R10 challenge
Hey rouvio Great Work M8
Can U Tell Us More Setting For Share Bro?![]()
Asus Crosshair IV Formula
Athlon X2 240 (For Now)
ATI HD5750 Silent
Kingston 2000HyperX CL9
GP1035B
Zalman CNPS 10X Extreme
Sorry For My Great English
I just bought a cpu with the same batch i hope it is great like this baby.
Great cpu you have there man, gratzAnd all i wished for was n i7 doing 4.2 easily
Nice avatar there Hazzan![]()
Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
