RUSTED GPU is Prawn approved.
Watch E.E.L. Embiense demonstrate how to use the Sophisticated Finishes products for adding a rust effect to your Mods.
http://www.youtube.com/watch?v=26Ud9T-doAc
I think Christopher left his scrap PC out in the rain a few times. To create those results, I apply the Iron Surfacer to the top panel first, then the Rust Solution after 10 mins. I repeated these steps over different locations on the exterior. The more Rust Solution you apply, the more Orange colored effect you get.
Wow, that's amazing work
Can't wait to see the finished product. You are really really really really really good at this man. Props!
Thank you for checking out the project and commenting!
There will be an MNU logo painted on this optical drive. Christopher likely traded something towards it, so he could view cd rom archived files from MNU perhaps?
More rust effects occur..
The new 600W Cooler Master Silent PRO didn't look right in a POS computer, it was treated to "rust lovin" as well.
simply amazing..cant wait to see final product...love the wire "sleeving" idea as well...
Thank you! Intel Core 2 Duo 3.16 GHz Processor in Intel DX48BT2 Motherboard sent by Cooler Master for their display.
I'm looking at this Cooler Master HYPER N620 and wondering ""What Christopher do differently with it?"
wow, damn, nice job, I loved the technique of aging.
SORRY FOR MY BAD ENGLISH!
Thank you! I wanted to direct the cooler air entering the front of the case to the cpu cooler. The 5.25 bay covers were removed to highlight the canister movie prop we made. It dawned on me that a fan duct could be mounted to a 120mm fan by modifying a 120mm round mesh fan grill. In the past, I would mold the fan duct into the front bezel with body filler, but this method is much easier and more versatile.
This method can be combined with 4.5" flexible tubing to isolate cool airflow. Imagine one end of the tube attached to a 120mm cooling fan in front of your case.
The 4.5" Flexible tubing can be found at Mcmaster, http://www.mcmaster.com/#duct-hose/=4zltce or you can "try" the "Heating & Cooling" department at hardware or home improvement stores like Home Depot or Lowes.
Supplies & Tools:
120mm Modder's Mesh Round fan grill, http://www.mnpctech.com/120mm_Custom_FanGrill.html
4.5" fan duct, http://www.mnpctech.com/FanDuct.html
4, #10 x 5/8" fan screws, http://www.mnpctech.com/thumbscrew.html">#10 x 5/8" fan screws</a>
120mm cooling fan.
Paint pen or pencil.
Tin snips.
Wire cutter.
Using a paint pen to trace the duct onto the round mesh grill.
a small wire cutter and Tin snips used to cut the 4.5" opening in the 120mm Modder's Mesh Round fan grill
You'll need to use the small wire cutter first, to make the initial cut before you can use the Tin Snips to cut the 4.5" hole.
Using Tin ship to cut the round mesh grill.
The result of you cutting should look like this.
120mm cooling fan. This fan has enclosed corners, you will need longer fan screws if you're mounting the fan onto something like a cpu cooler.
4, http://www.mnpctech.com/thumbscrew.html, #10 x 5/8" fan screws</a>
Our own Prawn canister is back from paint and ready for installation.
Original Prawn canister from District-9 movie
just impressive man,just impressive
Thank you! I need a massive bundle of wires. like what you see in the telecommunication's box for a building...lol
am i sleeping? Damn GOD MOD. The best of all.
Intel Q9550 E0
Prolimatech Megahalems + Xigmatek XLF-1253
Asus HD4870 512MB 810/1000mhz
A-data 2x2GB OverClock Extreme Edition 1066+
ASUS P5Q Deluxe 2301
CHIEFTEC 560W (CFT-560-A12S)
Maxtor DaimondMax STM3500320AS
CM HAF 922
Samsung T220 1680x1050
Vista x86 SP2
Incredible...I want to see MORE! =)
Loonym...You are missed.
The element of one
Breathe me in
Breathe me in
I disbelieve in separation. I close my eyes to see you.
This is for you, everything I am. This is for you, take it from me.
I, I disbelieve separation. I close my eyes
there's no escaping me
In your heart in your soul. I perceive rejuvenation
Breathe me in. I am forever. Deep within I am eternal.
I will return to you. I am with you always. I will never turn away from you.
Thanks guys! btw, you both have great avatars
Yesterday I painted the 2x 120mm cooling fans from the Cooler Master HYPER N620, will post those photos soon!
140mm Aerocool Fan for the exhaust, was also painted Matte White
Fan Grill made from Round Modder's Mesh, http://www.mnpctech.com/moddersmesh.html
I have probably a stupid question for you,after the 2010 CES,what will you do for this masterpiece of modding?
Will you sell it? or keep it for you?
'couse i think that this job go beyond a simple mod,this job is just ART,and so it should stand in a museum of technology
Amaaaazing
Rust? No thanks. Great job though.
Err, you do know it is fake rust, right?
IMHO I would have got an experienced airbrush artist to paint on the rust, they do really really detailed jobs still, this is just AMAZING!
I think with the prawn canister, you should have the cathode hidden in the side and fill the canister with water in the middle? or a UV cathode with reactive uv liquid?
just a thought
Patience is the only talent.
Wow one of the best build projects ive seen in my life, the movie was fantastic so is this!
there is a cathode inside the canister...
Current System:
eVGA 680i SLi "A2" P30 BIOS
intel Core 2 Quad Q6600 (currently at stock)
OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
320GB Seagate 7200.10
XFX 8800GT XXX 512MB (stock clocks)
auzentech X-Fi Prelude
PC Power and Cooling Silencer 750 Quad Copper
Win XP Pro
only negatives I have are...the mirrored acrylic looks like its getting scratched up (probably not intentional)..and the prawn canister looks too new (havn't seen the movie myself, so I can't really be a true judge)
Current System:
Win XP Pro
Yes, and more scratches will be added, I'm not finished yet I'm also debating on what type of extra cabling I want to use.
