Greetings,
Ok I'm in a dilemma here really, I can't figure out the best fan orientation that suits my case the best.
1- Should I push out air from inside the case to outside like this :
My case temp is usually between 30 and 32 when room temp is 24.
I won't be having a heat pocket but cooling is not at it's best in the RADs.
2- Should I push in the cold Air to the case like this :
Probably the best cooling from RAds, but in my case as I won't have any fans taking the hot air out the case it will cause a hot air pocket.
3- SHould I mix the pushing like this :
Not sure about that really.
Please advice as I can't figure it out.
Also note that my case has a 200mm fan on the left side panel to blow air all over the motherboard and one 120mm fan behind the motherboard try underneath the CPU that pulls air out.
