Hello people! I would appreciate any kind of help or ideeas regarding my problem. I'm not proud of what I've managed to obtain this evening. Till 2 hours ago I had 2 8800gts 640MB in SLI running happy at stock volts.
Now, one of the cards is on the table with one of the small SMD missing. It is circled in yellow in the picture from SFED's volt modding thread for 8800gts G80's.
I managed to drop a small bubble of solder over that SMD and it unsoldered when I tried to clean it. With this error not beeing enough for today, the SMD stuck on the iron's tip and, ..... you've guessed right .... I've managed to lost it on the table/near it on the ground.
So, does anyone know :
1. the card can run without that SMD or I'll trash it if I'll power it on (I've seen that the 2 SMDs and the empty pad betwen them share a common end towards the Primarion chip) ?
2. i have the second card at hand, but I don't think that I can willingly unsolder that SMD even in 100 years .... to check it's value.
3. can I put a VR in the place of the missing SMD and what value (I measured the resistance of the solder pads, it can be seen in the picture)?
This is SFED's original thread about 8800gts G80 volt modding (I hope that he woudn't mind that I've used one of his pictures): http://www.xtremesystems.org/forums/...d.php?t=123046
Any kind of help would be appreciated. Thank you. I'll try to read the pdf of the primarion px3540 controller but I'm limited in this field .... http://208.109.51.75/PrimarionMain/D...s/PDB-3540.pdf
