+ Reply to Thread
Results 1 to 4 of 4
Thread: Silverstone TJ-07 user help!!!
    Jan 2009
    0
    Hi guys, i am planning to buy a TJ-07 for the first time and i want to ask:
    1. Whether 2 MCR320 can fit in the bottom part of this case with the PSU laying down 180 degree instead of 90 degree (the case will be modded and the length of this case is 565mm while the MRCs and my corsair HX620 are 410mm and 150mm respectively)?
    2. What is the clearance of the bottom compartment (wide and height)?
    Thanks in advance
    Xtreme Cable Management Freak Mabyboi's Avatar
    Dec 2008
    Ontario, Canada
    1
    i know a quad and a double, and a triple and a double fit down there. as for two triples its hard to say, if you sandwhich two mcr-320's... maybe?
    Project: HeadShot
    Intel i7 3770k | Corsair H100
    EVGA GTX-590 Classified | XSPC GTX 590 Waterblock
    Gigabyte G1.Sniper 2 MotherBoard | Swiftech MCR-320 Res/Rad/Pump
    16GB Corsair Vengeance Low Profile Ram
    Crucial M4 128GB / Intel X25-M 160GB / WD 1TB Black
    Corsair AX850W PSU
    27" Apple Cinema Display (2560x1440)
    Corsair 600t White
    You best be Crunching and Folding/GPUgrid'ing!
    Xtreme Member r4st4m4n's Avatar
    Jul 2007
    0
    No it won't fit. But as said MaByBoI, you can fit a quad and a double, so you would have the same surface area.
    Q6600@3.6 GHz / GA-X48-DQ6
    2x2GB Kingston HyperX DDR2-800
    Asus HD 5870
    Corsair TX-850
    WD Velociraptor 150GB / WD Green power 500GB
    Water Cooling: EK res 250 > Swiftec MCP655 > Swiftec MCR320 > EK-FC5870 > HeatKiller 3.0 LT
    Jul 2009
    0
    you can download google sketchup for free and test different configurations of already made models
    http://scc.jezmckean.com/cat/11
+ Reply to Thread
