Ok, so I've decided that I want to sleeve my PSU to make tucking the wires behind the motherboard a bit easier; currently, they are running behind the mobo but the bulk of the 24-pin makes the PCB crackle a bit each time I move it, so I'm hoping that sleeving them individually will help correct this.
Please correct me now if I'm wrong!!!
Ok, so with that, I want to also shorten the distance between my SATA connectors - I'm not sure where the picture I saw of it was but, essentially, the SATA connectors on that line from the HX1000 were moved up so that there was only the necessary amount of cabling between each of the hard drives. Hopefully someone can help me out with a pic that I can't find atm.
And one last thing, splicing fan wires - should I solder them together, hook the strands together in the hook shape things? What's the best way to approach this? I've seen a lot of the finished products in the worklogs but the actual process has been a little hard to find.
Any guides, tutorials, etc would be great!!!
Thanks!
