Hello ALL!
I have extremely tweaked Windows XP and when I install AMD Overdrive, it doesn't start work Failed to start.
And I have a question
What kind of Windows component and services are necessary to run AMD Overdrive without any problems
Hello ALL!
CPU : AMD X2 5200+ @ 3Ghz
Motherboard : EPOX EP-AF590 SLI2 with Thermalright HR-05 IFX SLI
CPU Cooler : Thermalright Ultra 120 Extreme with Noctua NF-P12
Videocard : XFX 8600GT Fatal1ty Edition @ 700/1800Mhz
DDR : Teem Xtreem PC-6400 2X1GB @ 4-4-4-8 / 500Mhz
HDD : Sata II - 2 X Seagate 250GB ST3250410AS 16MB cach in RAID 0 ; IDE - Seagate 160GB, WD 80GB
PSU : Chieftec 600 Watt, +12V Combined 48A - CTF-600-14CS
CASE : Chieftec AEGIS CX-05B-B with 4 X Scythe SLIP STREAM SY1225SL12M controled by
Scythe Kaze Master 5.25 @ 1000RPM; 3 X Noctua NF-B9 @ 1000RPM
Monitor : HP L1740
speacker : Logitech X-230
Im not quite sure. my windows is tweaked as well but i can run overdrive without an issue.
you could do a process of elimination rebooting a hundred times. to me overdrive is kinda of useless. I would only use to troubleshoot. or like cpuz to check clocks and etc.
Why do you need overdrive? You should try changing your fsb first. just 1 or 2 mhz at a time.
AOD only works with AMD/ATI (7series and up) chipsets,yours
is Nvidia.Try the ntune maybe?
