Page 6 of 6 FirstFirst ... 3456
Results 126 to 133 of 133
Thread: i9 Gulftown paired with an EVGA Classified 760
  1. #126
    Aug 2008
    Quote Originally Posted by [XC] gomeler View Post
    I take it you have never run a CPU below -30C or so. Coldbug = CPU crashes due to being too cold. With the IMC on the CPU die you now introduce another complex piece of circuitry that you can coldbug and it may coldbug with a different set of parameters than the CPU cores. Just try to run most Bloomfields at -120C and let me know how it goes
    i played with with Dice and lnē on Bloomfield and others, only this one not yet.
    if you just say "coldbug", i know enough,
    your imc cb probs, i don't understand, my english is ot that good.
    3dmark Vantage : +47K (NO PhysX)
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
    Wprime32m : 3.233sec
    Wprime1024 : 1m30sec320
  2. #127
    Champion
    Feb 2007
    I think i know about the PSU troubles....
    Every bench monitored, my Corsair 1000W can t run 2D higger.
    I think can be the Power Supplie problem.
    Every time the drop kills the benchmark, and its the best i can reach with the Rampage 2 Extreme.
    R2E can t boot less than -81 Celsius and can t be higger frequency in the memory neither northbridge.
    The CPU freeze (any frequence) -101~-102 Celsius.
    i think is the only CPU haves Coldbug so low and the fXXXX motherboard don t help me to get higger.
    So soon i will post with the Classified and try better.
    Amazing insane result Hipro5...after this i noticed Gulftown 2.4 can be better than 3.07 Ghz
    P.S. Sorry the broken english , but the traductor is really not good
  3. #128
    Aug 2008
    that bummer that your coldbug is at -101°C.
    hope that you have better results on Classified mobo
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  4. #129
    Xtremely Addicted
    Dec 2004
    NL
    Too bad about temp Rbuass but nice uncore for i9.
  5. #130
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    Quote Originally Posted by rbuass View Post
    We tested i9 under cascade some days ago under RIIE and Classi. under RIIE I could boot -102 easy while we had problems on the evga past -75 (with and without jumper). due to the problems we couldn't test classified really but RIIE doesn't like nb without high QPI voltage. RAM likes CL8 on RIIE, I can do 1100MHZ 32m under air with 3.3 nb and 1.35 qpi. but clockwise for that temps I say it is ok but be carefull with the voltage - under load you have ~1.9V on that board and I am not sure if it is that good for the chip at this temperature.
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
  6. #131
    Mar 2009
    sick score !
    BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
    Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
    Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
    Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
    KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
    Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
  7. #132
    Feb 2005
    very nice Gulftown benching result
  8. #133
    Jul 2009
    Jp
    hello all
    Tell us little
    Gulftown Q3QN I was wearing, but "FF" from the POST does not display,
    What is the problem?
    E760 w3540 BIOS: S61J → 43 beta
