Oh, very nice .
Next time can you run for me a Winrar benchmark?
Oh, very nice .
3Dmark2006 Score Calculator
"Frequency Unlimit -Enabled'' by DFI
Oh my.. Very impressive!
Looks like you've been spurting coffee all over the keyboard with those results!
Edit, any 3dm06 CPU scores?
you need to get boreder and put the 5870s colder
any oc loss with new bios?
Great job, hipro
6 months before I9 come out but you are already having fun with them
Intel Q9650 @500x9MHz/1,3V
Asus Maximus II Formula @Performance Level=7
OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
OCZ SSD Vertex 3 120Gb
Seagate RAID0 2x ST1000DM003
XFX HD7970 3GB @1111MHz
Thermaltake Xaser VI BWS
Seasonic Platinum SS-1000XP
M-Audio Audiophile 192
LG W2486L
Liquid Cooling System :
ThermoChill PA120.3 + Coolgate 4x120
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
Apple MacBook Pro 17` Early 2011:
CPU: Sandy Bridge Intel Core i7 2720QM
RAM: Crucial 2x4GB DDR3 1333
SSD: Samsung 840 Pro 256 GB SSD
HDD: ADATA Nobility NH13 1GB White
OS: Mac OS X Mavericks
Coding 24/7... Limited forums/PMs time.
-Justice isn't blind, Justice is ashamed.
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
how much will the i9 cost whens its out ?
Yet another Gulftown at nearly 6.5 Ghz!
Great OC!
It's shaping up really nicely for extreme OCers.
cpu tweaker doesnt work??? thats odd, should be the same registers?
does it give you an error message that the cpu is not supported? in that case maybe all that needs to be done is add the cpuid to the tools startup detection?
yeah i noticed uncore isnt that high... so even at lower cpu clocks uncore wont go higher?
strange... have you tried lower block and skip some uncore multis? maybe some dont work properly for some reason? hmmmm
very promising results... almost 1ghz higher than 45nm chips
hey george, have you played with 32nm dualcores yet?
do the clock the same? higher? lower?
how HOT is gulftown on ln2 and high vcore? does it smoke a lot of ln2?
Good start George!
Not the golden CPU there, but still very nice scores
You are as good as your samples are!
Hipro what's up? You were in hurry and didn't find any toilet paper?
Hmm let's use the keyboard instead then!!
Anyhow love you work, insane results!
ROG Power PCs - Intel and AMD
wow sub 6min
Holy ! Those are some nice clocks.
Is that the one shammy had?
***** Visit us on PCWorld.fr *****
wooow, very nice cpu and nice benching as usual, thx for sharing
www.vitesse24.de
www.vitesse24.de
C2Q q6600 3.3GHZ @ 1,184V
4,5GHZ@ 1,52V ( 9* 500 )
Corsair Dominator 10000 2gb, 8888 2gb, 9136 1gb
Awesome! Gulftown is about to crush every WR out there.
Looking forward to some 3d mark 01 damage.
Keep smokin it!
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
wont be long till we need to add more 0s to superpi
did i just say that? i was just thinking aloud
you rock Hipro. totally amazing stuff! if i was your sponsor i would give you a new keyboard right away ! or is there a special overclocking aura in that keyboard ^_^! keep up the INSANE CLOCKS. 4x 5870;s would surely get 60k 05.. which is WICKED.
can you tell me one thing though, these 6.4 pi gulftowns, are they rare or do you think most i9's will reach around the 6ghz mark? like retails. will it be like E8600, some good some bad?
