Is haf 932 much better than stacker 830? Please state why or why not.
HAF is better in term of airflow and cabling management, but for the looks, I think stacker is the winner.
thanks for reply
is it better to have psu at the bottom or top ?
I have HAF922 at home waiting for someone to put parts to it. Going to do that at this weekend. It's for Phenom 2, GTX260 rig.
It's cheaper than HAF932 and has about as much space + some improved features from 932. Bi-Tech review.
I'm planning to write my own review too (my first review), but since I don't have other cases from that price range to compare it may be a bit hard to do it...
I would get Stacker if I had extra cash, but if you want to save some cash, HAF isn't bad either.
i7 920 d0 @ 4,4GHz | Water
DFI X58 T3eH8 | G.Skill Trident 3*2gb 1640MHz 8-8-8-20
Gigabyte GTX480 | Samsung 244T
TT Kandalf | TT ToughPower 850W
Samsung T166 500Gb*2 + F1 1Tb | Vista Home Premium 64-bit
from my experience is indeed better to have PSU at the bottom, especially in high full tower case, somehow it help with cable management by having PSU mount in bottom of the case. some of theories are bottom placement PSU also creating better thermal flow inside the case, and bottom mount PSU also reduce the vibration compare with top mount PSU, but I havent prove that.
I love my HAF932. The stacker is nice too but I prefer the 932. I like the PSU at the bottom too. Cleaner look and does not bother the big fan on top. :-)
*CPU: Xeon X5650 @ 4.3 Ghz | Cooler: Thermaltake Water 2.0 Extreme
*Asus Rampage III Formula | RAM: 36GB DDR3 (Tracer LED + Hyper X Savage)
*Video Cards: Gigabyte Aorus 1080ti
Sound Card: Sound Blaster Z | PSU: Corsair HX1000W | Display: BenQ PD3200u | JVC RS520 projector
*Case: CoolerMaster HAF X (932 side panel) | Others: Roccat Kone AIMO | Roccat Alumic | Logitech G15 |Cameras: Sony A7R3 | RX100 V
