Is there a driver for 5870 that is Futuremark approved.
No, but who cares, as long as we can get still HWboints
What's your score Runmc?
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
I'm running some 03 with single stage @ 4.8ghz on920. Card is at 1175/1315. Best score so far is 100866. Not even in the top 3 athwbot.
What is the fastest driver out now? Link
This is what I am using:
http://support.amd.com/us/kbarticles...icsdriver.aspx
Nice overclock. I just got my waterblock today, so hopefully I will be able to push the 1100 line.
Desk Build
W/C System
I'm using XP right now but I will switch to Win7 in a few. thanks
That is not a new driver its the same as the one dated 9/21.I spoke withe tech support from ATI and they have a new driver coming out next week. I use that driver and it didnt work for me would not show temps or current MHZ. I went back to the 9/21 which is supposedly the same but its not.
Xigmatek Elysium Case
Intel I7-3770K
Asus Sabertooth Z77
16 Gigs Ripjaws 2133mhz Ram
Mushkin 240 SSD
Lightscribe Dvd Burners
EVGA GTX 680
Aquacomputer Gpu Block
Cooler Master Hybrid 1050 Watt Pws
EK Supremacy Cpu Block
Xspc RX360 Rad
Xspc XS360 Rad
Phobya 250 Balancer Res
2 x Mcp 350 Pumps
i asume the futuremark approved is Catalyst 9.10 thats gonna be released on 22th aka windows 7 release day
FX-8350
