I would like to see any pictures of this mod
it is done with the stock cooler and a gpu core waterblock
thanks
thanks
1
Has this been done for the 5000 series yet? I've seen pictures of the mod for the 4000 series, but I thought that it wasn't possible for the 5870 because of the design of the cooler? Something about it covering everything, including the GPU, with a single piece of metal.
mhh i cant find it i thought i saw a picture of a 5870 with water block and its heatsink where you could unsrcew the cores cooling block and fit a water block on the core and still have the vrms and gddr cooled but the stock cooler
1
I don't think that can be done without breaking the cooler and doing some extensive modding. One would have to cut the GPU cooling element (fins & heatpipes) out of the frontplate as they seem to be soldered into the frontplate. I'm not 100% sure on this - but I am pretty sure this is the case.
You were not supposed to see this.
I know you can use water block for core and stock plate for vrms/memory for 5850. But I believe 5870 has its metal plate + core cooler all attached into 1 unit, so some major cutting would be needed.
Motherboard: GigaByte P67UD4 f6 | CPU: Intel 2500k 4.5ghz 1.26v | Memory: GSkill 2x4gb @ 1600mhz 1.34v | PSU: SeaSonic X650 Gold 650W | Video: AMD 6970 Koolance water block 880c/1450mem 1.035v | HDD: WD 640gb cavier black: VelociRaptor 300gb: Intel x-25 g2 80gb | Sound: Asus xonar D1 | OS: W7 64bit
all i've heard/seen is speculation on the feasability of this mod. would love some concrete pictures.
i hate you : P
Well since Bill picked up three FC blocks for the 5870 earlier at my place, I guess he doesn't need to care any more
I'm sure that while he's dabbling with the blocks he would tear apart one of them 5870 stock coolers and see if the cooling element can be removed from the faceplate...
Heehee... concrete ...
I just looked at my cooler since I installed the EK block. The original cooper heatpipe block is solder to the original front plate. You would need to unsolder it from the front plate to install a water block or other heatsink.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
There are pics somewhere of someone who has done it with a 5850.
i5 4690k @ stock on Apogee GTX
MB ????
RAM ???
HD6970 on mcw60
PA120.3
Custom Built Case
My Blog:
http://www.destructoid.com/blogs/Locke
http://www.xtremesystems.org/forums/...2&postcount=50
5850 w/ mcw60-r2 + stock plate
But the core heat sink isn't attached to stock plate like 5870.
Not sure how much solder, but it does look like a thorough job. Keep in mind if you were to unsolder it, that would void the warranty, even with XFX, so I wouldn't do it if you care about the warranty at all. You would be better off using ram sinks or getting the Swiftech heatink that goes with the MCW60.
Desk Build
W/C System
swiffy doesn't yet have a sink for the 5870 (though they might by the time i grab one)
i'd probably try snagging a spare stock cooler from someone who went FC water block and whose warranty expired before i tried this. You could also resolder it together yourself. Thanks for the heads up, though.
