+ Reply to Thread
Results 1 to 11 of 11
Thread: mountain mods pc switch
    Xtreme Addict Circaflex's Avatar
    Dec 2004
    Southern California
    2
    hey guys i have an old u2 ufo and i lost the bolt for the switch that is standard on them. does anyone know off the top of their head what size it is? thanks
    Pentium 4 3.2E (SL7PN E0) @ 4246.46 MHz (265.4 * 16) 1.48cvore
    Intel Core i7 3930k@ Stock (Still testing) - ASUS Rampage IV Extreme - 16GB (4 x 4gb) GSkill TridentX@ Stock - 2x eVGA GTX 670 FTW - Creative Titanium HD - 2 x Cruicial m4 256GB SSD (RAID0) - 4 x 74GB Raptors (RAID0) - Antec TPQ-1200
    Phase unit by runmc @ full load -33
    H2O Loop - MCP35X+Heatsink w/RES>MCR320-XP>MCR320-XP>HeatKiller GTX680HoleEdition>HeatKiller GTX680HoleEdition
    Jul 2007
    0
    Email us - we can hook you up as we have a few extras.
    Dec 2004
    Southern California
    2
    anyway you can let me know the size nut it is? I emailed but little pricey IMO for a nut, i just need the size so i can call around my local auto shops and lowes/home depot. thanks
    ... IFMU's Avatar
    Nov 2001
    Wichita, KS
    5
    I think I may have the right size nut you're needing.
    Not sure how to figure the measurements though, if you can tell me what you need on it, I might be able to get you those measurements.
    Dec 2004
    Southern California
    2
    Quote Originally Posted by IFMU View Post
    im not quite sure i under stand the bolded part. http://www.mountainmods.com/nickel-p...tch-p-216.html that is the switch
    ... IFMU's Avatar
    Nov 2001
    Wichita, KS
    5
    How do I figured the size of it? That is the part I don't know how to do.
    Dec 2004
    Southern California
    2
    ok i understand now, these are the universal switches for the u2-ufos, they also have other colored switches with this size listed 22mm diameter but i do not know if that is the switch head (the actual button) or the threaded screw size. Maybe mountain mods could chime in one more time with the size?
    ... IFMU's Avatar
    Nov 2001
    Wichita, KS
    5
    Well with mine presently in a packed system, I'd rather not pull it to try to get measurements. But if MM fails to get you the size, let me know, you can do by posting in here and I'll pull it and get you what measurements I can from it.
    Dec 2004
    Southern California
    2
    thanks a lot, ive sent MM a pm and another email to see if they can give me the actual size.
    Dec 2004
    Southern California
    2
    no response from PMs to MM or emails on the actual size, guess they want me to fork over money instead of just giving me the info.
    Dec 2004
    Southern California
    2
    i was able to finally find a nut, not even sure what size it is. Happen to pass a local mom and pop auto shop, stopped in to see if maybe they carry random nuts and bolts for car swtiches etc, they had one that fits. thanks for the help though ifmu
+ Reply to Thread
