Just for troubleshooting purposes, try a modular one. Also, quite a few 8800 series GPUs had "buzz" issues. Do you have access to another GPU with which to test?
Yes, Yellowbeard, a tall rough man with a big yellow beard
Check our forums, including the sticky post BUZZING NOISE FROM POWER SUPPLIES-POSSIBLE SOLUTION
You should also post in our forum as they deal more directly with these issues on a daily basis. Let them know that this is your second PSU.
Glad I could help and I hope you are satisfied with the PSU.
It's odd that it came and went. Have you cleared the CMOS? Check the BIOS and see if your C1E setting has changed.
There are more steps in that thread I linked so hopefully you can resolve it. Also, you should go ahead and post at the Corsair forum in the PSU section.
Yes thanks for the share and keep up the good work.
