Well if you are going to be doing tests with dedicated hardware cards only two benchmarks are reliable and wil lgive you reproducable results, and that is i/o meter and everest. ATTO will give you so many borked readings you will be tearing yoiur hair out LOL it does not handle cards well AT ALL. The big key is being able to reproduce the results, one run to the other, if your benchmark will not do that then you know that it is having issues. I am speaking from my experiences with SSD and harware raid, but i have heard from many that they have the same issues with hardware hdd raids. Consider using Everest really for read only tests, requires blank disk for write testing, but i/o meter will give you awesome results, and the bootup profile has a mix of commonly used input/ouput patterns that are used in a normal everyday usage of an OS, lots of small files used randomly. There are some really good info HERE ALSO there are downloads for different profiles in the second post.
